Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 12-18-2012, 04:55 PM   #1
jdwarren
jdwarren's Avatar
Drives: 2013 chevrolet camaro rally yellow
Arrow [DIY] Non RS headlight to RS headlight conversion + Front Bumper Removal
NON RS -> RS HEADLIGHT GUIDE
Hey everyone, this is my first DIY!
I will try and keep it short and sweet.
This DIY is to take your regular Non-RS (halogen) headlamps and switch them out with the RS (Halo/HID) headlamps.
FINISHED PRODUCT:
Tools Required:
10mm socket wrench
7mm socket wrench
(Sock wrench extension helps)
Flat head screwdriver
T-20 torque screwdriver
*Essential Item*
You must have a wiring harness to convert your Non-RS power supply into a RS power supply.
You can buy this wiring harness from www.gen5diy.com
Plug and Play harness ($150)
http://www.gen5diy.com/PnP_harnesses...ight-harness-2
IF YOU WANT DRL HALOS (LIKE MINE) YOU MUST CUSTOM MAKE YOUR HARNESS. TALK TO GEN5DIY.COM FOR A CUSTOM HARNESS.
Quick Summary of what to do:
1) Remove front bumper
2) Remove stock halogen lights
3) Install wiring harness
4) Install new RS lights
5) TEST LIGHTS
6) Put front bumper back on
I used this video to take off the front bumper, you can use it too. You can see exactly how to take everything off and in what order to do it. This is not my video and I do not take any credit for it. It is simply an extra "helper"
Detailed Summary With Pictures:
If you have any questions about a step, or do not understand me, or you are stuck and need help. Feel free to ask questions and/or PM me. Good luck!
STEP 1: LAY BLANKET DOWN & POP HOOD
STEP 2: TURN WHEEL TO FAR RIGHT/LEFT (Some people use a car-jack to lift it to make it easier, I did not want to mess around with a jack-lift so I switched between far left and far right to get the screws)
STEP 3: REMOVE 2 BOLTS FROM BOTTOM OF BUMPER
STEP 4: REMOVE 6 SNAP SCREW ON BLACK PART (TOP OF BUMPER)
STEP 5: REMOVE 3 TORQUE SCREWS IN WHEEL WELL (PLASTIC)
STEP 6: REMOVE 2 BOLTS- 1 BEHIND THE YELLOW BOLT & 1 BELOW BLACK PART OF SIDEMARKER LIGHT (INSIDE WHEEL WELL)
STEP 7: REMOVE 3 – 10MM BOLTS FAR IN WHEEL WELL (TOWARDS TOP OF BUMPER ON THE INSIDE)
I do not have pictures of this, but look around the wheel well and you will see these plastic "pop out" pins that hold the wheel well tight on the car. You can remove as many of these as you would like to move the wheel well more easily so you can get to the bolts easier.
STEP 8: REMOVE 2 BOLTS ON EACH SIDE OF TOP OF BUMPER. WHEN THIS COMES OFF, IT IS FREE!
STEP 9: REMOVE BUMPER BY UN-PLUGGING SIDEMARKET LIGHT WIRING HARNESS ADAPTER (FRONT LEFT OF CAR)
*IMPORTANT* MAKE SURE YOU PUT YOUR BUMPER ON A TOWEL/SHEET SO IT DOES NOT GET SCRATCHED!!!
CAR WITH BUMPER OFF AND HALOGENS IN...
STEP 10: REMOVE OLD HEADLIGHTS: TWO BOLTS ON TOP OF LIGHT AND TWO ON BOTTOM
CAR WITH FRONT BUMPER + HEADLIGHTS REMOVED
STEP 11: INSTALL NEW “RS” HEADLIGHTS (SCREW IN 4 BOLTS)
STEP 12: PLUG IN OLD AMBER LIGHT ADPATER
STEP 13: PLUG IN GEN5DIY HARNESS FROM OLD HALOGEN LIGHT POWER-> NEW HARNESS - > NEW RS HID LIGHT
STEP 14: FOR DRL HALOS: PLUG IN ADAPTER BETWEEN FRONT BUMPER AND SIDEMARKER ADAPTER
STEP 15: FOR DRL HALOS: PLUG IN “ADD A FUSE” 10 AMP TO THE 5 AMP IGNITION FUSE POSITION - SHOWN IN PICTURE
STEP 16: TEST LIGHTS!!!
IF LIGHTS WORK...... REINSTALL FRONT BUMPER BY GOING BACK 1 BY 1
ALL THE SCREWS...
STEP 17: MOUNT RELAY HARNESS ONTO FUSE BOX HOLE (I used a zip-tie)
Cut zip-tie to desired lenght...
FINISHED PRODUCT:
1ST PIC- DAYTIME “AUTO” DRL HALOS
2ND PIC- LIGHTS TURNED ON
Me and my Car.. Just for fun :P
jdwarren is offline   Reply With Quote
Old 12-18-2012, 05:09 PM   #2
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
Excellent DIY!!!!
Monchy36 is offline   Reply With Quote
Old 12-18-2012, 06:35 PM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
You did a good job on this can i use it on the site?
2SSRS@Gen5diy is offline   Reply With Quote
Old 12-18-2012, 07:23 PM   #4
ChevyCam13
ChevyCam13's Avatar
Drives: 2013 Chevy Camaro 1SS LS3
Nice DIY I will be installing mine this weekend. The only thing Is I didn't know about having the harness custome to run DRL halos I thought the harness already did that.
ChevyCam13 is offline   Reply With Quote
Old 12-18-2012, 10:25 PM   #5
sonnydurden
sonnydurden's Avatar
Drives: ‘16 1SS & ‘19 1LT
Hey Jason, I believe the harness will allow us to use the rs headlights in a fashion similar to the rs Camaros...on our car the DRL is in our headlights, on the RS the DRL is in the fog light...so I'm guessing we can turn on the halos by themselves when we turn on the park lights only just like they do on the RS...but having them as DRL is cool as hell!!!
sonnydurden is offline   Reply With Quote
Old 12-19-2012, 12:42 AM   #6
sonnydurden
Great DIY!!!!
Old 12-19-2012, 10:20 AM   #7
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Great write up Jon. You've really got me on the fence now about doing this. Question though. Did you bake your lights or buy a stock pair of RS lights to replace your orginals?
WiSSDiver is offline   Reply With Quote
Old 12-19-2012, 10:25 AM   #8
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
He bought a stock pair of rs lights
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 12-19-2012, 02:31 PM   #9
jdwarren
jdwarren's Avatar
Originally Posted by Monchy36 View Post
Excellent DIY!!!!
Thank you very much! I have been browsing camaro5 since the day I got my car (3 weeks ago). So i thought it would be nice to give back to this awesome camaro community
Hey Ofer! Absolutely You helped me so much with the harness that I will help you out in anyway possible. Thank you!
Originally Posted by sonnydurden View Post
Great DIY!!!!
Thanks Sonny!!
Hey rpomeroy, I did not bake my lights at all. I replaced the ENTIRE light. I had to buy the RS headlights from someone online. So I currently have 2 sets of headlights - (1) pair of RS headlights. & (1) pair of non-RS headlights. I am leasing my car so when I have to turn it back in (3 years from now) I will have to put my halogen headlights back in.
*EDIT* I have added pictures of where to mount the relay for your harness.
If anyone has any questions, please feel free to PM me or ask them in this thread
Old 12-19-2012, 03:10 PM   #10
sonnydurden
Thanks Sonny!!
Thanks for adding a picture of where to mount the relay...
Old 12-20-2012, 11:03 AM   #11
malave7567
malave7567's Avatar
Drives: 2015 Camaro 1SS
excellent write-up. I'm thinking of going down this route in the future and this is a great DIY to learn from. Also, when I saw all the bolts lined up... I had a moment where I said, "oh s***! cat eyes! where'd that cat come from!"
malave7567 is offline   Reply With Quote
Old 12-20-2012, 04:01 PM   #12
ChevyCam13
ChevyCam13's Avatar
I asked ofer about that he said i needed to add a fuse so i got one i just dont know where it goes lol
Old 12-20-2012, 11:03 PM   #13
khabboub
Tampa Gulf Coast Family
khabboub's Avatar
Drives: Sold c7, in the market!
i did this a while ago, awesome mod. the lights are a million times better
khabboub is offline   Reply With Quote
Old 12-24-2012, 09:18 AM   #14
sonnydurden
JDWarren shows where the fuse goes in the pictures, however it looks like there is an extra wire coming from the harness....I dont remember seeing that piece on the harness that I ordered...My order will be here on Friday...my birthday ...I will look at it then...I think JD's is a custom harness from Ofer...
bumper, headlight, non-rs, removal, rs conversion drl halo
