Old 07-03-2017, 04:54 PM   #1
uxof
Drives: 2016 V8
wheel alignment specifications
Hello everyone!
I recently hit curb with my Camaro and my steering wheel isn't straight now.
I have my own workshop to check and fix alignment but i need factory wheel alignment specifications.
My Car is 2SS 2016 MT with MRC and SE3 RPO.
Could any of You help me?
Best regards!!
uxof is offline   Reply With Quote
Old 07-03-2017, 05:54 PM   #2
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
...............Camber .................Toe
Str Front -.75 deg +-.8deg .2deg +- .2 deg
......Rear -.9 deg +-.8deg .2deg +- .2 deg
Track Front -1.5 deg +- .15deg .1deg +- .05 deg
.........Rear -1.25 deg +- .15deg .1deg +- .05 deg
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 07-08-2017, 03:53 PM   #3
uxof
Drives: 2016 V8
Thank You very much!
Old 12-22-2017, 12:06 PM   #4
Soleil
Soleil's Avatar
I know it’s an old thread but does someone have the Wheel alignment specifications a bit more readable. PDF?
Soleil
Old 12-26-2017, 09:26 PM   #5
JaxChris
Front camber -0.75
Front cross camber 0.00
Front toe 0.05
Front total toe 0.10
Rear camber -0.90
Rear cross camber 0.00
Rear toe 0.05
Rear total toe 0.10
Alignment should be done with the vehicle weighted for the driver. The aggressive front caster on the 2016+ Camaro (~7.5 degrees stock) causes camber to change noticeably when front passengers are added (and toe slightly due to camber flex). Find a shop that will let you sit in the car while they adjust everything to your preferred specs.
If you want more front cornering and a bump of oversteer, you can change the front camber to -1.25, but all other numbers should stay the same. The car has a slight understeer with the factory specs. For a more neutral steering experience, a -1.00 front camber compensates for the track width difference between front and rear. If you run square tires (LS/LT trims) then equal camber front to rear of -0.90 to -1.00.
I would lean toward the lower numbers if you're more of a go fast driver and not the "never waste a corner" driver.
