Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 03-26-2015, 11:09 AM   #1
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
lightweight wheels vs. 1/4 mile times
I've been thinking about buying some lightweight 18" wheels and tires. Looking at either the TSW nurburgring about 18lbs each or maybe forgestar f-14's. I love the Welds but probably a little out of my price range. Right now I'm running the factory 20" wheels which are 30+lbs.
How much could I expect to take off my 1/4mile times from this change only. I don't spin at the track now so this would be just the unsprung weight reduction, not better traction. I remember when I replaced my PZeros with general gmax's(6-7lbs lighter) I could definitely feel the difference, the car just felt lighter and more nimble. I'm thinking this will make quite a difference.
JantzenOKC is offline   Reply With Quote
Old 03-26-2015, 11:46 AM   #2
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
A tength or so maybe, I remebr running stock 20's in the back then tsw nurginbuging now 18's helped on the 60ft some as well. The biggest is changing the fronts to a skinny I just recently got of my 20's in front down to a 17x5 dropped a tength and half but they are welds not cheap $1363 for front set my rear set coming in 2 weeks $1700 XD. But it should help over all rotating mass decrease helps the most
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 03-26-2015, 12:45 PM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
I would look into race stars if your in a budget.
Skinnies are important IMO
62nalide is offline   Reply With Quote
Old 03-26-2015, 01:26 PM   #4
nightmaro10
nightmaro10's Avatar
Drives: Ibm SS/RS
I also dropped a tenth and a half. Maybe a little more from switching to skinnies. I'm running the race star darkstars up front.
nightmaro10 is offline   Reply With Quote
Old 03-26-2015, 01:31 PM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I would imagine every pound of wheel/tire weight you save is like 3lbs of static weight. Rough estimate and not exact science but it does add up. From my figures stock wheels and tires weigh about 260lbs total. TSW Interlogos/Nurburgrigs with MT 305/45R18 rear, 225/60R18 Continental Pure contact Eco Plus front weigh about 190lbs for a 70lb weight savings. 70lbs of wheel/tire weight savings is pretty big. I would imagine 70lbs of wheel/tire weight to be worth at least .2tenths and 2mph in the 1/4 mile.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 03-26-2015, 01:39 PM   #6
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I cant seem to find any info on it online but ive heard from two different racers that 1lb spinning weight is equal to about 7lbs static weight. I know when i switched to my welds it felt a lot faster.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 03-26-2015, 05:06 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Yeah +3, skinnies are a very good mod.
Stock 20" fronts are like over 60 lbs and wide. 17x4.5 Race Stars for example shod with a set of M/T drag radials would be like 40 lbs and have much less rolling resistance.
Race Star fronts I sold to a forum member, I'm a dealer for them:
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 03-26-2015, 06:29 PM   #8
JantzenOKC
JantzenOKC's Avatar
Well it seems the concensus is a skinny for the strip.. I didn't realize the contact patch made that big of a difference, I was just thinking weight. I was wanting something I could use for the street and the strip. Do any of you guys drive on the street with 4.5" fronts?
ProStockJohn that race star and mt tire look bad@ss.. i could see running something like that. I just don't want to have to put my heavy stockers back on for the street(where I spend most my time).
Old 03-26-2015, 07:19 PM   #9
nightmaro10
Drives: Ibm SS/RS
I run my 17x4.5 on the street to and from the track. I don't really run them around town, mostly because I don't wanna put a whole lot of wear on the tires. I went with the bias ply M&H and word is that they wear very easily. They are also slightly lighter than a radial tire, which was another reason for my choice. Can you run them around town? I know plenty of guys in my area that never take them off of their cars. Should you? That's up to you. I know from personal experience that skinnies won't handle or corner as well as other wider tire and wheels set ups. My only real input here would be to go with a radial up front if you plan to street them. Here's a pic of my track setup.
Old 03-26-2015, 08:00 PM   #10
Pro Stock John
Writer
I run a radial on mine and leave them on from now to Thanksgiving.
I will add matching rears when the 17's come out.
PROJECT HEAVY CHEVY
Old 03-26-2015, 09:34 PM   #11
JantzenOKC
JantzenOKC's Avatar
So you run a 17x7? What tire are you running on the front John?
Old 03-26-2015, 09:50 PM   #12
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
Really like the looks of those Pro Stock John
JD_Alaska is offline   Reply With Quote
Old 03-26-2015, 10:32 PM   #13
Pro Stock John
Writer
I'm running a 215 regular radial up front, idea came from Mike N aka Bad70Supreme.
PROJECT HEAVY CHEVY
Old 03-26-2015, 10:34 PM   #14
Pro Stock John
Writer
BHillaakabergwhatever has 215s on 17x7s up front, here is a frontal shot:
PROJECT HEAVY CHEVY
