03-26-2014, 11:01 AM | #1 |
Drives: Alfa Romeo Brera V6 Join Date: Jan 2013
Cams in LLT
Hi Guys, so im looking at upgrading my LLT heads with the bigger LFX intake valves but i also want to do cams, unfortunately due to my Crap country currency ZAR, i can never afford The Mace camshaft, but i did find out the LFX has increased duration and also is something i can afford! lol so is it possible to fit the LFX cams in the LLT? and if not, why not?
Or should i get my cams reprofiled perhaps?
[/URL]
Alfa Romeo- Only passions, great passions can elevate the soul to great things |
03-26-2014, 11:54 AM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
Your Alfa has the same engine as the V6 camaros?
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
03-26-2014, 04:39 PM | #3 |
Yes the alfa basically only has a 3.2 LLT but i bored it out and put in 3.6 internals so now its 3.6 LLT.
Apparently Fiat Group developed the LLT head for GM in exchange for their Alloytec global engine design, after the deal for Fiat Group to buy out GM fell through the floor GM has since redeveloped the LLT head into their own LFX we know today But, i digress, now about those cams....
[/URL]
03-26-2014, 06:28 PM | #4 |
Drives: 2011 LS Join Date: Jul 2013
Anyone one have the CAM journal measurements?
BBK Long Tube, HF Cat, RX ICE-Olator, RX OCC, C.A.I Intake, ADM Scoop, ROTO-fab washer relocator, Hurst short throw, MagnaFlow Cat-Back, VMAX TB; ENKEI RAIJIN 19x9.5; HANKOOK Ventus V12 evo2 275/35zr/19 Coming soon... HPtuner... I hope... |
03-26-2014, 07:40 PM | #5 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
This applies only to the LFX, don't have any info on the LLT
03-27-2014, 01:52 AM | #6 |
Just had a look at the alfas technical data also and it suggests that the lift is the same, unfortunately i cant find the duration data but yes this supports the fact that only the duration is increased on the lfx cam, i read somewhere that the lfx oil gallery might be located at a different area but i dont know how true this can be.
[/URL]
03-27-2014, 01:53 AM | #7 |
and thanks for the informative spec sheet RacnJsn95!
[/URL]
03-27-2014, 01:53 PM | #8 |
according to my alfas technical specs its the same as on the sheet posted above
Cam Journal diameter: 26.936 - 26.960 mm
[/URL]
03-27-2014, 02:00 PM | #9 |
Drives: Camaro LLT Join Date: May 2012
You might want to also look into the LFX pistons also, as they have a higher compression ratio that the LLT. LLT is 11.3 to 1, and the LFX is 11.5 to 1 comp ratio.
01-27-2015, 09:27 PM | #10 |
Drives: 2010 LLT victory red Join Date: May 2012
Bump what happen to this one, wanted to put lfx cams in the llt , but no show of any gains
