Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 09-23-2013, 10:04 AM   #1
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Project: Building a 12sec N/A LLT
Disclaimer: I understand that are far easier ways and cheaper ways to get these cars into the 12 sec range ex. Nitrous but that takes away from the whole point of the title. So please if you have nothing nice to say or can't contribute then please don't waste our time and post. However if you feel like it may not work please be nice about it and try to give some reasons as to why
So for the longest time I had this idea in my head. I have always wondered if it would be possible to get these cars into the 12s without going FI. And of course when I say into the 12s I mean breaking 13 flat so like 12.99999 lol. I know it may be a long shot considering the known fastest N/A LLT to me is ROD1 who has gone 13.42@103.22. I know it may be a long shot but I am curious to see if it can be done and I know it will require some $$$ lol.
As of right now my fastest pass is a 13.564@102.51. That was with a D.A of 1186. Now my mods on this pass included:
Rotofab CAI with Apex Scoop
Vmax Ported Throttle Body
Mace Stage 3 Ported Intake
Plenum Spacer
Vmax Black Ice-olator
BBK Long Tube headers with HFCs
Trifecta Tune
LS3 Midpipe with MRT v2
20x10 Nurburgrings all round with General Gmax tires
Pfadt Trailing Arms and Outer Trailing Arm Bushings
LSR Front and Rear Sway Bars
Gasket matched head ports (not sure if this makes a difference)
LSR Toe Rods
Megan Racing Coilovers
MT DR's and Skinnies
Took off roughly 294lbs (this includes the weight of the skinnies)
Everything I have done so far for weight loss can be see here (I'll try to keep this updated as I go):
Originally Posted by kjkjr27 View Post
I am gonna use this post to try and do an as accurate weight changes as I can with each mod that has been added or what has been removed. Some things may be pointless to weigh but this is more for me to get an idea of what is going on lol.
Red= weight loss Green=Weight Gain
Starting Weight: 3749 _________Estimated Weight: ~3469 --> 3600 with full tank
Weight Loss: 280.4lbs
Exhaust: Stock:48lbs MRT v2:19lbs --> 29lbs
Wheels: Stock:124.6lbs Nurburgrings 20x10: 98lbs --> 26.6lbs
Pirellis: Stock: 136lbs General G-Max 275/40/20: 120lbs --> 16lbs
Lug Nuts: Stock: 3.14lbs Al Lug Nuts: 0.94lbs --> 2.2lbs
Engine Cover: --> 2.5lbs
Washer Bottle: 2lbs (empty) Apex Scoop and W/W Relocator (empty) 4lbs -->2lbs
Spare Tire and Kit: --> 47.1lbs
Apex Catch Can --> 2.98lbs
Valve Covers (removing felt and oil extension tube) --> 1.19lbs
Misc. Engine Stuff: --> 1.54lbs
Stock Pedals: 0.15lbs Powdercoated Billet Pedals: 0.65lbs --> 0.5lbs
Stock Rotors (front and rear) : 76.83lbs R1 slotted/drilled Rotors (front and rear): 73.76lbs --> 3.14lbs
Remove Front Dash Speaker--> 0.68lbs
Stock Headers and Cats:39lbs Ceramic Coated BBK Lts w/ HFC: 28.38 -->11.62lbs
Stock Trailing arm and outer bushings: 6.06lbs Pfadt Trailing Arms and outer bushings: 5.12lbs --> 0.94lbs
Stock Sway Bars: 11.74lbs LSR Sway Bars: 15.58lbs --> 3.84lbs
Remove Rear Seat: --> -41.93lbs
Stock bars: 41.28lbs HMR Custom Bars: 19.01lbs --> -22.2lbs
Stock Toe Rods: 4.16lbs LSR Toe Rods: 2.5lbs --> 1.66lbs
Stock Struts/Springs: 61.74lbs Megan Racing Coilovers: 43.04lbs --> 18.72lbs
Stock Battery: 45.15lbs Braille 17lb Battery: 16.85lbs --> 28.3lbs
Stock Grill with Bowtie and RS badge: 2.75lbs Heritage Grill: 2.13lbs --> 0.63lbs
SS Rear Upgrade --> ???
Stock Drivehsaft: 23.15lbs DSS 1-piece Al Driveshaft: 24.94lbs -->1.79lbs
Stock LLT Intake Manifold: LFX Intake Manifold: --> 11lbs
I know a lot more is needed to even get close to this goal and as of now I have a couple things in mind to help get me there (or anyone for that matter). Now some of these things I have already looked into and can be done while others may need a bit more research. So far this is what I have been thinking of adding:
Performance
SLP 25% Underdrive Pulley
Dyno tune with Hp Tuners
Rear Subframe Inserts/Bushings
Rear Upper Control Arm Bushings
Driver Mod
Weight Loss
Driver Mod
Optic Armour Windshield and Side windows (loss of ~14lbs)
One tricky thing about this is my car must maintain all the comfort features for daily driving and I do not want the interior all torn out.
I am hoping some of you can help and add things to the list that I either forgot about or don't know about. Figured this would be a cool thing to come together on as a community. Sadly in the next two months my car will be going into storage so things may not get interesting for awhile, but that gives me a lot of time to research haha. I am determined to see if this is possible lol even if it will take awhile.
Useful links:
http://www.camaro5.com/forums/showthread.php?t=161969
http://www.camaro5.com/forums/showthread.php?t=356418
Weight loss
http://www.camaro5.com/forums/showthread.php?t=170965
http://www.camaro5.com/forums/showthread.php?t=267027
Old 09-23-2013, 10:09 AM   #2
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Gears, 3.91 or 4.10. A Mustang V6 van get into 12's N/A but needs at least 3.73 gears and they have a 300 lbs advantage.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 09-23-2013, 10:19 AM   #3
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
If RacnJcn's "Adaptolator" pans out, you may be able to put his ported LFX IM (also in development). That should be good for a few pounds and could possibly flow as well as, or better than, the Stage 3 LLT IM...
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 09-23-2013, 10:24 AM   #4
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
That would require me to upgrade to the SS rear end though right in order to have those?
True, if I remember correctly the LFX manifold is like 11lbs lighter than the LLT one.
Old 09-23-2013, 10:31 AM   #5
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
You can remove the passanger seat when going to the track...that weighs more than the rear seat.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-23-2013, 10:35 AM   #6
MagnumForceGB
Yeah, its an expensive upgrade. I plan on upgrading mine to a 1LE diff, but I want an 11 second car.
Old 09-23-2013, 10:35 AM   #7
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Yes it would. And if i am not mistaken it also would require a new drive shaft which you already plan on doing one so that shouldn't be a huge issue.
Old 09-23-2013, 10:44 AM   #8
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Kevin, as much as I too would love to see either you or I get into the 12's running N/A, personally I don't see it happening. Either you will need to drop another approx. 400 - 600 lbs from the current weight. Or find another 40 - 60 HP. Neither which I think can happen.
I too have damn near every bolt on. Only thing missing is the SLP Pulley. That is not going to add much and is not worth the time, effort and return for me to invest into this mod.
My opinion for many of these other mods are as follow:
Driveshaft; good idea, but expensive.
IPF tune; not going to get you much more than the Trifecta tune you currently have today.
Tie Rods; minimum amount of extra help for our builds.
Coilovers; minimum amount of extra help for our builds.
Stall Convertor; great idea but has not proved out for our builds to be of any help.
Mace Cams; not a true bolt on, I am not looking into these, and from what I have seen have not proven themselves out as a end all cure all for some worth the cost HP.
Skinnies and slicks, now you’re talking some real help. Look at the top few on the drag list and you will see they were sharing the same set-up for their passes.
Driver mod; check back in a year and I might have something for this one, and I will leave it at that. Could be worth a tenth or two in my pass.
Taking out the back seat is worth approx.. 30 lbs. unless you remove some seatbelts and brackets too.
Battery will save some weight but not that great of an idea for a daily driver.
Yes, in order to get to the 3.91 or 4.10 gears you will need an SS rear end. But your feul economy will suffer for the good of a few passes and a quicker ET. I thought about this one too, but my Camaro is not a drag racing car first, so why make that much of a sacrifice for what I truly have it for (DD).
Good Luck, I will be following your ideas and build as it goes.
PS: I plan to be at the strip again soon and HOPE to generate a new PB. Time will tell.
rtcat600man is offline   Reply With Quote
Old 09-23-2013, 11:30 AM   #9
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Thanks for the advice, I don't mind doing stuff like that that can easily be put back together for daily driving.
Good luck
Mike unfortunately you are prob 100% right. It may be impossible to do. Even if it isn't me personally doing it it would be cool to see if this can help out someone be able to do it.
I don't mind people saying it isn't posibble as long as they give a reason as to why they think so. I put in the disclaimer to hopefully prevent all the trolling and other nonsense people love to post on these forums.
Old 09-23-2013, 11:44 AM   #10
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Kevin what was the 60 ft on your pass at Indy?
I personally do see it being a possibility. And if I had the funds, I'd already have tried it. But it hinges on one thing. LMR willing to tackle the dyno tuning on anything I throw their way.
Here's why I say this. If LMR is willing to dyno tune the mace cams, I think it's possible. Reason I mention LMR is because I fully believe a true dyno tune is best over a mail order tune. If the dyno testing of the mace cams wasn't a fluke and theirs at least a 30hp gain to be had, it becomes something more attainable. Let's just say theoretically we r going with the 10hp = .1 reduction in ET or 100 lbs = .1 reduction in ET. Adding the possible 30+ hp of the cams reduces your et by .3. I don't see how you can't gain some ET with some proper traction and some more ET with some weight reduction. I fully believe that a proper converter on these cars will help (Read: not rx trash) and if it does, I think 12s is attainable.
This is all speculation and hopeful thinking from me though.
Either way, I think the mods with the most impact if you're aiming for that 12 second slip are good tires, a good converter, and cams (if the gains weren't a fluke)
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 09-23-2013, 12:05 PM   #11
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
My 60ft on that pass was 2.099
Old 09-23-2013, 12:07 PM   #12
lscamaro
lscamaro's Avatar
A 1.9 to 1.8 will give you some better et
Old 09-23-2013, 12:24 PM   #13
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Hoping the trailing arms and outer bushings help. I know the track was prepped beautifully down in Indy. Unfortunately the one near me not so much
Old 09-23-2013, 12:52 PM   #14
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
I too am looking for that 12.99 pass. The biggest gains you will see will be from gearing, and drag wheels with skinnies up front. After fully bolting on the car, start working on reducing weight. Ie carbon hood, trunk, fenders, and doors if you feel froggy. Weight is the biggest disadvantage us V6s have. PFADT suspension will help in more consistent times, and weight savings. Good luck brotha!
RenegadeSS is offline   Reply With Quote
12secbuild
