TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 06-03-2021, 08:28 AM   #1
blewbyyou
blewbyyou's Avatar
Drives: Dusk SE
brake reservoir
i have noticed that the brake fluid reservoir has oozed some fluid
and the reservoir is messy. has anyone had this issue?
I replaced the pads with Hawk green pads and changed the rotors to drilled and slotted ones a couple of years ago and I`m not having any braking issues other than the pads sounding somewhat aggressive as I apply the brakes. maybe just a loose cap with a weak seal.
Daily Drives Dusk SE 2SS/RS
blewbyyou is offline   Reply With Quote
Old 06-03-2021, 08:58 PM   #2
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Start with new seal/cap
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 06-04-2021, 08:23 AM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
There was a cap recall for that IIRC but not sure if yours was included.
Did you overflow the reservoir when you pushed the caliper pistons back during the brake job? That could cause a temporary high fluid level. Just a thought.
Stingr69 is offline   Reply With Quote
Old 06-04-2021, 12:56 PM   #4
cdb95z28
cdb95z28's Avatar
A loose cap can contribute to seepage, but the cap and the diaphragm are designed to relieve pressure from heat build up. The diaphragm has a small slit in it and the cap has a tiny relief path that will exit onto the top of the reservoir. If you had installed new pads and had to push the caliper pistons back into the calipers a fair amount, this could raise the fluid level within the reservoir, increasing the chance of seepage.
Old 06-04-2021, 12:58 PM   #5
cdb95z28
cdb95z28's Avatar
Old 06-05-2021, 10:39 AM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Actually early Gen5 had a problem with the reservoir as well as the cap not providing a good fit.
Search the site.
