12-15-2015, 08:24 AM | #1 |
Drives: Z/28 15 AGM Join Date: Sep 2015
Chevrolet Complete Care for Oil Change?
Anybody using Chevrolet's Complete Care program for oil changes in the first two years, 24K miles on their Z/28?
I'm approaching 1500 mi and time to change the break-in oil. I expect it should be included in the Complete Care, but need to find that out. Also, did they only install the UF48R filter, or will they install a PF64, if you ask? I expect that may be pretty much dealer-dependent. May not help that I bought mine from a dealer 150 mi away. |
12-15-2015, 08:58 AM | #2 |
another debate here...the UPF48R is the factory fitment however the Track sheet says to use the PF64. All of the Z06 guys have used the UPF48R for years 2006-2013 Z06 with the LS7. I personally use the PF64 all of the time. Local parts chains like Advance Auto and Autozone don't stock the PF64 so I purchase them from Amazon. A member here called the GM hotline and had an engineer tell them the return drain holes are bigger on the PF64 so that is why that is the filter of choice.
12-15-2015, 09:11 AM | #3 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
My dealer just changed my oil and they used the UPF48R. Not saying either is better, but I will be doing my research before the next change.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
12-15-2015, 09:27 AM | #4 |
Drives: 2014 Z28 Join Date: Apr 2015
I am using Chevrolet's Complete care program, It's my understanding that it is 3 or 4 oil changes only, 2 years time or 24,000 miles. I was told that I could have them change the oil as often as I want until I have used up the free oil changes. I have 9,500 mile on my car getting ready for my 3rd oil change at 10,000 miles, didn't know about the filter differences
they installed gm part #12626224, I checked the cross reference to AC Delco and it is a PF64 filter I hope this helps you. |
12-15-2015, 09:47 AM | #5 | |
Drives: Camaro 1LE Join Date: Nov 2015
12-15-2015, 10:34 AM | #6 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I think I got charged for my oil change at 1500 miles:/ I will be checking in the spring when I get it changed again, just over 5000 miles now
UPSTATE C5 MEMBER
12-15-2015, 01:40 PM | #7 |
Drives: 2023Porsche Cayenne S Join Date: Jul 2010
I left Chevy Che the maintenance. Didn't even care to check what they use. One the free oil changes a done I'll stock up on all the proper set is parts
12-17-2015, 07:08 AM | #8 |
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD Join Date: Dec 2014
Like I'm going to have some Bozo at the the dealer changing oil in my Z/28.
The more I stay away from a dealership the better... |
12-17-2015, 08:10 AM | #9 |
what does that mean?
UPSTATE C5 MEMBER
12-17-2015, 08:43 AM | #10 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
12-17-2015, 10:36 AM | #11 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
Get a set of Race Ramps and do your own changes, for peace of mind! That way you know for sure all 8 qts came out and what filter you really want to use.
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
12-17-2015, 11:52 AM | #12 |
Drives: 2014 white Z/28 Join Date: May 2014
Silly thing with me is I like to take the apron off and clean all the trash it collects. and it gives me the chance to check for bad things like leaks, loose fastners, chafed sensor wires and the like. I was to the understanding that the pf64 filter is used for the 15w50 race oil and the upf48r is used for the 5w30ep. As the two filters have different bypass psi and filter media.
12-17-2015, 05:12 PM | #13 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Fixed it for you. Another reason to do it yourself. Not everyone will know to pull both oil pan plugs then top off your motor with old fluid still in the pan or worse in your sump.
12-17-2015, 05:46 PM | #14 |
ewrball4
Drives: 2014 Z/28 WHITE #9700211 Join Date: Sep 2015
What would you all do? I went ahead and had my oil changed this past week and after reading this Thread. I found out that my dealership went ahead and used the oil filter GM 19303975. Is this going to end up being a problem. I guess it can be used on the ZL1 but not the Z/28. I just need some advice if I should make an issue on this oil filter.
