Old 07-22-2020, 04:50 AM   #337
2011SS2SS
2011SS2SS's Avatar
Drives: 2011 Camaro SS w/2SS
Originally Posted by davidscamaro View Post
Dude no , dont use that "modded"sensor. Send it back and get ac delco
OK... Why??
2011SS2SS is offline   Reply With Quote
Old 07-22-2020, 09:41 AM   #338
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Originally Posted by 2011SS2SS View Post
OK... Why??
Those aftermarket maf give bad reading
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-22-2020, 12:46 PM   #339
2011SS2SS
2011SS2SS's Avatar
Really?? You've experienced this?? I am a curious type of guy, so I want to know as much as I can...
I read a bunch of reviews on it before purchase & did not see anything about it... But you never know if those people reviewing it would know if it was giving bad readings.
Old 07-22-2020, 04:08 PM   #340
davidscamaro
Scene the being of fuel injection there has always been maf mods , most intale puting a resistor on one of the wires so the 5 volt signal to the ecu gets told to add more fuel, and that's the slight chance it works at all .
often the heated spring or strip gets a open air concept and the ecu does not know what to make of the new 5v signal and cant give proper air fuel
The hole reason GM puts honey comb "old style" and "air paths" with the maf sensors is to get the values the ecm can work with
Old 07-22-2020, 04:15 PM   #341
davidscamaro
some aftermarket intakes even add honey comb air screens to help the maf sensor get calmer air to not throw off the maf values, being stock with sensors is important
Old 10-21-2021, 04:04 AM   #342
vampiloutre
Drives: 2011 Camaro RS/SS
I suspect my maf to be bad.
I live in France, so i can’t check by myself weak or strong maf when i buy one.
Have you any good source to get a stock strong maf ?
vampiloutre is offline   Reply With Quote
Old 10-21-2021, 07:21 AM   #343
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check here...
https://gwatneyperformance.com/produ...le-maf-sensor/
1JEWLDSSRS is offline   Reply With Quote
Old 10-22-2021, 05:50 AM   #344
vampiloutre
@1JEWLDSSRS thanks but it’s backorder on their site :(
My maf seems dead so i can’t wait
Old 10-22-2021, 07:42 AM   #345
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow, I think you're gonna find a lot of stuff for our cars on back order, unfortunatly. Good luck...
Old 11-23-2021, 12:34 AM   #346
blackout_zl1
Drives: camaro zl1
im going from a roto fab cai to a 5in cai and ported sc with a 102tb and my tuner is haveing a field day trying to tune the car. they unplugged the maf and the car would idel around 1800. with the maf plugged in it would run for about 3 secs and die. im having him look at the maf tomarrow and see if we got a strong or weak one. but could this be the reason we are having problems tuning the car?
blackout_zl1 is offline   Reply With Quote
Old 11-23-2021, 09:48 AM   #347
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check here, post# 7.. This could be your issue since you increased your intake tube diameter like Bo did. GL..
https://www.camaro5.com/forums/showthread.php?t=585753
Old 12-14-2023, 12:12 PM   #348
Celticclark
Celticclark's Avatar
Drives: 2010 CamaroSS 1954Belair 28 Model A
How much for the "strong" MAF?
Celticclark is offline   Reply With Quote
Old 12-14-2023, 03:34 PM   #349
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Post # 343 if you are for real. lol.
apex, bucking, maf, surging, weak
