02-03-2018, 04:29 PM | #1 |
Drives: 17 1LE, 17 BMW 340, 18 F-150 Join Date: Nov 2017
Koni Shock Install - Help
Switching out front and rear struts for Koni's but having some issues tightening the top nut on the rears (I'm assuming I'll have the same issue on the fronts). There's no hex nut or torx bit to put a wrench onto to stop the shock shaft from spinning when tightening the nut. And holding the adjuster with pliers just seems like a bad idea. I've tried with both the spring compressed and spring uncompressed, no luck shaft continues to spin.
If this was a cheap shock I'd just use an impact to tighten the nut but these are custom-valved shocks that cost me a pretty penny and I don't want to damage them.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold |
02-03-2018, 05:20 PM | #2 |
Drives: cars Join Date: May 2011
On every other adjustable system the adjuster piece comes out and an allen wrench fits in to hold it for torquing.
02-06-2018, 10:55 AM | #3 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Use the KONI included nut and lock washer, instead of the factory locking nut for the shock.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
02-07-2018, 12:55 PM | #4 |
Drives: Camaro Justice Join Date: Jun 2007
Bump it with the impact. As long as you don't sit there and jack hammer it, a bump or two won't hurt it.
02-07-2018, 03:21 PM | #5 | ||
That's what I ended up doing, used my electric impact which doesn't have much torque and just bumped the nut on until I had ~1.5 threads sticking out past the nut like the stock shocks did. Hopefully when it comes time to remove this isn't an issue
2017 - SS 1LE
02-13-2018, 09:32 AM | #6 |
Drives: '14 RRM 2SS/RS,GMC Syclone, LPE T/A Join Date: Sep 2016
DO NOT use an impact on any shock with a Koni Wet kit in them. We repair 5-10 sets a month that someone used an impact on then broke the adjuster trying to get them off of full tight. When you spin the shaft clockwise with an impact suddenly the threaded adjuster nut wants to not spin, this tightens it up. If you set them to full loose you would reduce the chance of damage but it is still there. There is a special wrench with a rubber sleeve on it that clamps around the shaft to hold it. You clamp it down on the shaft then you hold the shaft while turning the nut. I just looked in my invoicing software and I have billed out repair on a stuck adjuster 717 times in the last 10 yrs.
02-13-2018, 10:25 AM | #7 | |
02-15-2018, 07:22 PM | #8 | |
2017 - SS 1LE
