TireRack
Old 08-04-2017, 03:59 PM   #1
Blue70SS
Blue70SS's Avatar
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry
Pro & Cons of TVS2300 Rear Cog???
As the title suggests, what are the pros and cons of going from the serpentine rear jackshaft belt to a Cog setup? I just shredded a new rear 14 rib for the first time. I hit the rev limiter like 3 to 4 times in first gear in the 1/4 mile with high boost and the belt blew about. 7 sec before the finish line. I know the Cog setup won't slip, and it sounds like the 30mm wide can get torn up super easy by hitting the rev limiter at all if high boost. I'd be interested to hear everybody's experience with the Cog versus power levels and especially if anyone's gone to the 50mm rear COG set up. I saw on one of the vet forums where when using the Lingenfelter rear tensioner that they would basically just tighten the Cog up by pushing down with their hand on the Idler.
LPE 650+,IOM Pearl White Rallys
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC
NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc
Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions
DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit
RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS
Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop
StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock
PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit
LPE Brotherhood
Blue70SS is offline   Reply With Quote
Old 08-04-2017, 04:11 PM   #2
Blue70SS
Blue70SS's Avatar
Rev limiter could be raised to 7000 or 7200 from my current 6800 just to be sure its never hit safely.
LPE Brotherhood
Old 08-08-2017, 10:13 AM   #3
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
No cons in my opion no slip and a nice super charger sound. I've been running the over driven set up for 4 or 5 years now.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 08-08-2017, 02:01 PM   #4
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Pro - more power without slip.
Con- noise.
Unavowed is offline   Reply With Quote
Old 08-09-2017, 02:55 PM   #5
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
Con- noise.
Agreed on the pro but disagree on the con. Mine was loud at the beginning but I love it. It's how a supercharger should sound if you ask me.
Outlaw77 is offline   Reply With Quote
Old 08-10-2017, 03:04 PM   #6
Unavowed
Unavowed's Avatar
If you're into the whole loud car, lumpy cam, open header, rednecky noises thing, sure. I prefer more refinement and less noise, but I'm over 40, so..
Old 08-11-2017, 12:13 PM   #7
Outlaw77
Outlaw77's Avatar
I'm over 40 as well. I have a nice smooth and quite truck that I drive mostly. When I feel restless I fire the beast up and I feel alive again! Loud, lumpy, smelly and stupid fast. Full of awesome.
Old 08-11-2017, 12:45 PM   #8
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
+1 for ~ 2yrs but I was having issues with front belt slip. This fixed it, lol!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 08-11-2017, 12:48 PM   #9
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I don't even notice the sound of the cog. I don't think it's that loud... or maybe I can't hear it over my exhaust.
newagemuscle is offline   Reply With Quote
Old 07-29-2018, 06:06 PM   #10
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
i've seen a few pics of some vette guys shredding cog belts by hitting the rev limiter, too
Eve ('00 FRC): hot-air intake
Old 07-29-2018, 08:49 PM   #11
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Little increase in boost with with OD drive cog belt with the 3.8 pulley. The noise of the cog belt can belt can be adjusted a little. The tighter the belt the louder the noise will be. I did switch over to the od cog belt due to belt slippage.
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 07-29-2018, 08:51 PM   #12
lincoln361
lincoln361's Avatar
oh yeah, you will need to swap or grind down on the passenger fuel rail so the 36mm cog pulley will fit
Old 08-10-2018, 02:08 PM   #13
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
How does high boost and hitting the rev-limiter have a direct relationship?
Stefano is offline   Reply With Quote
Old 08-10-2018, 03:35 PM   #14
zebra
zebra's Avatar
i could be wrong, but the way i understand is that the heavy load on the blower at high boost combined with the rev limiter causing abrupt, repeated RPM changes that it over-stresses the ribs on the cog belt.
