06-14-2017, 10:50 AM | #1 |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Those who installed the McLeod RXT clutch... step in side.
I just got my car back last night from having the clutch installed. This seems like it will get a little to get used to. It has a completely different feel for me. It's not that the pedal feels any heavier, it's just the clutch engagement point feels that much earlier. Did any of you guys feel the same way? I realize it probably won't have the same feel as stock... I am just curious to hear some other impressions after your install was done.
Thanks
06-14-2017, 04:29 PM | #2 |
Philippians 4:13
Ttt
06-15-2017, 10:36 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
It probably just needs to be broke in for a few hundred miles. Mine got better with time
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
06-15-2017, 09:24 PM | #4 |
Drives: 2011 2SS Inferno Orange Join Date: Oct 2013
I got one of these after installing SPEC clutch in my CAMARO. You can adjust it to bring your engagement point closer to the floor. Works well !
You will have to bleed your clutch after installing it. https://m.summitracing.com/parts/ram-78305
2011 Camaro SS
Buckets of money under hood! |
06-16-2017, 05:13 AM | #5 |
Light pedal, slightly lower engagement, slight chatter for a few hundred miles were all normal after install. About 75 passes down the strip, light pedal, engagement in the middle of the throw and no chatter...also this clutch does not like being slipped. I do bleed my clutch after I take the car to the strip
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
06-17-2017, 06:00 AM | #6 |
Philippians 4:13
Thanks guy
06-21-2017, 10:22 AM | #7 |
Drives: o Join Date: Jun 2017
Nice ride!
If you don't mind me asking, who did your clutch install? I need a new clutch and all the shops near by said they would rather not do it. Thinking about doing it myself, but sure would be nice to have some one else do it. Then I can go fishing while its getting fixed |
