Go Back   CAMARO6 > Marketplace > Members Classifieds > Interior Parts & Accessories
Old 02-14-2018, 05:35 AM   #43
bigtexhand
bigtexhand's Avatar
Drives: 2017 Garnet Red 2SS
Mine's been installed for a couple of months now but I haven't noticed any difference in manual mode ups or downs. I'll play around with it the next time I've got it out though. Since it all attaches above the shift bezel I wouldn't THINK it should affect it other than the "feel" of the movement because of the weight maybe?
bigtexhand is offline   Reply With Quote
Old 02-14-2018, 12:37 PM   #44
HurstPerformance
HurstPerformance's Avatar
Drives: 2013 Camaro SS and 2016 Camaro SS
Originally Posted by bonecrusher5150 View Post
I do have one. Installed it over Xmas. And just the other day was played me around with the shifter and it won’t downshift but will upshift
That should certainly not be the case. Give us a call at 707-544-4761 and we will gladly help troubleshoot your issue and get you taken care of.
You are correct, your use of the shift handle in manual mode should not be affected. It should still operate as it would from the factory.
If anyone is experiencing any issues at all, or if you just have questions, do not hesitate to give us a call at 707-544-4761. We are always happy to help.
HurstPerformance is offline   Reply With Quote
Old 02-15-2018, 11:13 AM   #45
bonecrusher5150
bonecrusher5150's Avatar
Drives: 2017 Camaro 1SS Mean Green
I certainly will call thank you. And just to make sure here is the box ID
bonecrusher5150 is offline   Reply With Quote
Old 02-15-2018, 08:24 PM   #46
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
I'm about to pull the trigger and order one of these for my 2017 SS. I would like to hear from those of you that have them currently as to your opinions?
I had a chrome pistol grip on my 2010 SS (not hurst) and liked it a lot. Any input would be greatly welcomed.
Mahalo
Haole is offline   Reply With Quote
Old 02-16-2018, 07:51 AM   #47
bigtexhand
bigtexhand's Avatar
bonecrusher5150 - I took mine for an hour of stop and go driving in manual mode yesterday and it performed flawlessly. I couldn't get it to act up at all no matter what I did but hopefully someone else here will help you get it sorted out.
Haole - I loved mine from the start and just swapped to the rosewood grips...now I'm really really loving it. The feel of the diamond patterned wood is completely different from the smoother machined aluminum stock grip plates and I think the blackwood is a third texture so you should be able to find something you'll like.
I've seen a few post from folks that wanted something other that the HURST logo and since the stock plates are solid aluminum I'm wonder if their local engraving shop could modify them by taking a .005" off the surface and adding something custom.
Old 02-16-2018, 08:42 AM   #48
Haole
2017 SS
Haole's Avatar
Thank you Bigtexhand, I loved the one on my 2010 and just wanted some input on this one. I am by far not a cheap person. I just couldn't see spending $40 plus shipping here to Hawaii. I'm having it sent to family for free then flat rate to me for right around $15.
I will post after i get it installed.
I'm actually thinking in my mind to just plasti dip the inner portion where the label is white. if it doesn't turn out good I can always peel it right off. I place the order this morning.
Now just wait time to get it
Old 02-17-2018, 09:54 PM   #49
bonecrusher5150
All I figured it out. Yes it does work. Just have to apply more pressure than before. Kinda sticks but it works
Old 02-18-2018, 08:30 PM   #50
KROLIS
KROLIS's Avatar
Drives: 2017 2LT/RS & 2013 2LT/RS vert
Better get it now or it will be the the ones for the 5th gens
KROLIS is offline   Reply With Quote
Old 02-19-2018, 11:26 AM   #51
Haole
2017 SS
Haole's Avatar
Does anyone have or know of an installation video for this? I can only find videos for the manual transmission. I have downloaded the pdf from hurst website but I would also like to see a video if possible.
Old 02-19-2018, 12:14 PM   #52
bigtexhand
bigtexhand's Avatar
Haole, I used a combination of the instructions they sent and Lethal's clip:
and it was pretty straightforward. Removing the shift bezel worried me but it's more durable that you might think.
Old 02-19-2018, 04:57 PM   #53
Haole
2017 SS
Haole's Avatar
This is the video I was looking at and figured it would be easier.
Old 03-22-2018, 06:16 PM   #54
HurstPerformance
There's no better time to get that Hurst Billet/Plus Shifter for your 6th gen Camaro than now! From now until the end of March 2018 you can save up to $75 off of any qualifying Hurst purchase instantly. This offer is only available at hurst-shifters.com or by calling us at 707-544-4761.
automatic, handle, hurst, pistol grip, shifter
