TireRack
Old 10-19-2013, 01:32 AM   #1
AdamEL
Adam E. Lucchesi
AdamEL's Avatar
Drives: 2010 1SS/RS LS3 VR
Send a message via AIM to AdamEL
Loud pop from under the car while in reverse [not the brakes]...
I did a search for this and couldn't find this exact topic. So feel free to link me if you know of an existing thread.
Tonight, when I was backing out of my garage, I heard a pretty loud "pop" come from the bottom of my Camaro. It was just sort of out of nowhere. I was in reverse, just letting the clutch out [no gas] to ease it down the driveway. I was about 15 seconds or so into my backing out when I heard the pop from underneath. My wife definitely noticed it, too, and that's saying something...
The noise was very similar to the popping sound that your brakes can make when you wash your car and let it sit overnight, and then fire it up the next day or so. When you release the brakes to move the wheels, they'll almost always pop at you. My V6 and my SS both did it, and I know it's common, especially with big wheels. But I don't think that was it because my brakes weren't wet, I had driven the car to work today and there was no rain all day. And additionally, I was already well into rolling the car. So I'm pretty confident that's not the culprit. But the noise was similar to that brake pop.
When we got home, I crawled under the car, and from what I can tell, everything looks good, although I'm not a mechanic. The only mods I have are an Apex Skip-Shift Eliminator and DMH exhaust cutouts. The cutouts look and sound fine, so I doubt that's the problem.
Anybody have any idea what this might be? The car seems to be running as great as ever, so I'm not super worried that it's something crazy. But if anybody thinks I should have it looked at, I will definitely do so.
Thanks for the advice.
AdamEL is offline   Reply With Quote
Old 10-19-2013, 06:34 AM   #2
wayner
wayner's Avatar
Drives: White SSRS Convertible Edelbrock SC
Sometimes when you drive over a larger stone at low speed on the very edge of the tire it will fling the stone sideways ,making a loud pop.
Just one scenario to think about
wayner is offline   Reply With Quote
Old 10-19-2013, 07:01 AM   #3
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
Mine did this once while backing out, i was turning and thats when i heard it.
dealer said it was the differential clitches letting loose.. it had been sottong for 3 weeks and limited slip clutches were"grabby"
i have since added redline gear oil...quieter rear end and no more popping.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 10-19-2013, 10:20 AM   #4
AdamEL
Adam E. Lucchesi
AdamEL's Avatar
This sounds very possible! And I WAS turning the wheel at that time. Did your dealer recommend that gear oil, or you just did that on your own? Can that pop damage the car in any way that you know of?
Thanks for the info!
Old 10-19-2013, 11:50 AM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Since you have a '10 it could very well be this.
http://www.camaro5.com/forums/showthread.php?t=225109
GM accidentally left out these washers during the first half of the '10 MY. At first it only happens after you've been going in one direction for 10-15 seconds but eventually it gets bad enough to do it immediately after.
Mr_Draco is offline   Reply With Quote
Old 10-19-2013, 11:23 PM   #6
AdamEL
Adam E. Lucchesi
AdamEL's Avatar
Thank you for the link! I watched the video and actually read that entire 6 page thread, but that clicking noise doesn't sound anything like what I heard. Mine was way more of a loud "pop" and it was well into my roll and my wheels were turned. I really don't think that's it. However, I am having a tough time understanding weather or not my VIN falls in that category or not. The OP claimed his was in the affected range, but according to the VIN decoder, his should have been the 109,067th Camaro in 2010, not the 9,067th made. Unless I'm somehow misunderstanding that code. My VIN is 2G1FS1EW7A9109564. Do you have any idea if that falls in that date range or not? I'm not hearing that type of click noise, though...
Thank you for the help.
Old 10-20-2013, 12:12 AM   #7
harrycamaro
harrycamaro's Avatar
Drives: 2010 camaro lt w/ chrome 20's
I think I've heard my car make that noise. A little bothersome but I didn't think it was a big deal. Looks like imma have to go pay more attention to it
harrycamaro is offline   Reply With Quote
Old 10-20-2013, 04:49 AM   #8
dcoates18481
Dealer added a friction modifier after changing the gear oil.
I went to redline because i like their products and the modifier is already in the oil.
a matter of preference really.
I LIKE TO GO FAST!
Old 10-20-2013, 08:49 AM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Yea you're not understanding how the last 6 digits are decoded. When you are trying to figure out what number your car is, just ignore the 1. The 1 just means that it is a production model. The preproduction builds had a 0 in this slot. Once the build count reaches 100,000 it gets more complicated.
Your car is the 9,564th car made. I think GM was making about 400 cars a week at this time so you car was made just a little over a week after his. I don't know what the cut off is but with your car being so close to a car that we confirmed to be effected, it's a very good chance that your car also has this issue.
Old 10-20-2013, 09:12 PM   #10
AdamEL
Adam E. Lucchesi
AdamEL's Avatar
That makes perfect sense. Thank you for the clarification on the VIN number. I want to get it at least looked at for the missing washer. However, mine definitely isn't making that noise. That one guy chimed in on that thread saying that it wasn't all of the models made in that 97,000. So maybe I lucked out on that. But then again, some guys weren't noticing the noise until 30,000 miles and up. Mine only has 6,000 miles on it, so maybe I've got a ways to go. Either way, I'll certainly get it looked at.
Do you have any idea weather or not the absence of that washer can hurt the vehicle in any way?
Old 10-20-2013, 09:12 PM   #11
AdamEL
Adam E. Lucchesi
AdamEL's Avatar
Oh, okay, gotcha. Thank you for the info.
