01-09-2016, 06:27 PM | #1 |
Drives: 14 1LE Join Date: Jul 2013
227/235 610/610 114
are these good specs for a dd?? i know it's probably a little on the bigger side.. any idea of what lower rpm power would look like compared to stock? say 2500 rpm..
01-09-2016, 07:00 PM | #2 |
Drives: 2011 2SS Join Date: Aug 2014
I have 229/236 615? On 112lsa. Its a Texas Speed cam. It comes around 3500 and pulls really hard to the limiter. Low speed driving is slightly affected but its easy to drive around, you will get used to it quickly. But 6th on the fwy is fine, it will cruise at pretty much any reasonable speed in 6th. I usually sit around 2000 and its fine.
01-09-2016, 07:06 PM | #3 |
is it more of a turd than before cam below 3000?
01-09-2016, 07:15 PM | #4 |
Drives: 2015 CAMARO 1LE Join Date: Oct 2010
My cam specs are a little bigger then the one listed. I had no low end losses at all, all gains, a lot has to do with the tune though.
2015 CAMARO 1LE
01-09-2016, 07:24 PM | #5 |
care to share the specs so i can compare?
01-09-2016, 08:01 PM | #6 |
I did a custom grind to my specs from cam motion. 229/238 604/604 113+3. Usable power was important to me, peak power at 7k is useless in these heavy cars in my opinion unless you just want a dyno number.
2015 CAMARO 1LE
01-09-2016, 09:16 PM | #7 |
nah i dont care about the dyno number. i just want it to perform.
01-10-2016, 12:49 AM | #8 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I always recommend staying below 227* or so intake duration for the street.
01-10-2016, 06:10 AM | #9 |
01-10-2016, 07:36 AM | #10 |
Im not a big cam fan. 227-228 intake duration is the break over point on power by what Ive seen. Once you pass that point total power gains slow down and driveability starts to suffer.
01-10-2016, 08:29 AM | #11 |
Yes on the ls3 I like to keep the intake lobe less then 230, on a smaller bore engine I go just a drop smaller.
2015 CAMARO 1LE
01-10-2016, 09:00 AM | #12 |
01-10-2016, 04:32 PM | #13 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
I guess that's a good safe recommendation, but I find my cam perfectly streetable. That being said, I also don't sit in stop/go rush hour traffic hardly ever. To each his own, and maybe drivability is different on an automatic.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
01-10-2016, 07:29 PM | #14 |
Drives: CTS-V Join Date: Aug 2008
I thought it was to much overlap/intake revision that kills drive-ability .
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
