09-26-2014, 12:33 PM | #43 | |
Drives: Chevys at the limit Join Date: Nov 2010
Best regards, Tyler 888-308-6007 |
09-26-2014, 04:45 PM | #44 |
Drives: BRM 2LT RS "Mara" Join Date: Aug 2014
Definitely. I'm running solos, mrtv2, resonated x pipe, and cut out stock resonators and my car sounds great! When I start it every morning, it's like someone turned on a subwoofer in my garage. Just all deep bass sound.
09-26-2014, 04:59 PM | #45 | |
09-26-2014, 06:48 PM | #46 |
Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
I've got solo cats (they have a built in resonator), deleted stock resonators, and Mellow tone axle back exhaust. I love the sound. A bit of drone at highway speeds over 75 but she's not a road trip kind of car Super pleased with the improvement over stock setup. And not to be a wise guy but that sound your looking for sounds like a V8 with a cam, just not reproducible on a 6 cyclinder.
09-30-2014, 12:32 AM | #47 | |
Drives: 2012 Camaro Inferno Orange Join Date: Sep 2014
Which brand resonated x pipe? What type of solos'? Sorry, I'm a noob to these upgrades. |
01-19-2015, 07:29 AM | #48 |
Drives: holden ve v6 SIDI 3L Join Date: Jan 2015
hi guys attached are some headers i made in australia for my gm holden LF1 3L Direct injection engine basically same as the LFX just in a 3L option
anyway more bout the headers 2 1/2 stainless with 100 cell cats they produce the most unique sound for a v6 video http://youtu.be/pSOa2tZg2bE on mace/trifector tune search my channel for newer videos on full dyno tune sounds lumpy now like has cams but is just cam phase edit on the efi live tune http://youtu.be/Eww9wltjvpw |
08-18-2016, 07:04 PM | #49 |
Drives: 2013 v6 auto 1LT Join Date: Oct 2012
OK I WATCHED THE VIDEO, i see a cai on this car that i like any info . ORSSOM PERFORMANCE ?
10-07-2016, 09:33 PM | #50 |
Drives: 2015 Dodge Challenger R/T Scat Pack Join Date: May 2016
So are these like a thing now or are there just ARH, SOLOs, and the one other brand that is slipping my mind right now.
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein |
04-08-2017, 02:13 AM | #51 |
Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
Sry for being slow or new to the V-6. After watching the video, our headers are basically built in to the heads?
04-08-2017, 06:37 AM | #52 |
Drives: 2015 Z/22 Join Date: Aug 2015
Indeed. This engine incorporates "integrated exhaust manifolds" so the manifolds are built right into the cylinder heads, and so instead of manifolds ("headers") being bolted to the engine you'll see just a single 2.5" pipe on either side.
The LLT engine used in the 2010 and 2011 Camaro has normal/external headers, but also seems to have lots of issues with head gaskets leaking, timing chains loosening, etc., so anyone considering a V6 Camaro would be wise to go with a 2012+ unless they're highly mechanically inclined
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
