Vararam
Old 07-04-2016, 12:12 PM   #1
skongolf
Drives: 2011 2SS RS Black Vert
Vibration/Rattle from underneath
I have a 2011 SS Vert and lately when going over bumps I have noticed a rattle/shake from underneath that at times you can feel through the floor pans. It only does it when going over larger bumps in the road but it has gotten more noticeable lately. I thought it may be a broken exhaust hanger but I got under the car yesterday and everything seemed to be tight. Just curious if anyone ever had a similar issue or may know what else to check.
skongolf is offline   Reply With Quote
Old 07-04-2016, 01:15 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
With a rubber hammer hit your cats, they can be coming loose from inside. Also hit your mufflers and resonators.
Dimitrim is offline   Reply With Quote
Old 07-04-2016, 01:55 PM   #3
skongolf
When I hit them with the rubber mallet what should I be listening for? Also the car has a flowmaster exhaust so I am not sure the mufflers are causing the rattle as it is under the floorboards but I will check them. When you say coming loose from the inside what do you mean? Coming apart(failing) or just coming loose from the pipes. Thanks
Old 07-04-2016, 03:42 PM   #4
Dimitrim
Dimitri
The exhaust also has heat shields. Check to make sure they are not hitting anything.
When you hit the cats and mufflers they should sound solid when you hit them. If they don't they need to be replaced.
Old 07-04-2016, 06:53 PM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Most likely Flowmaster related...either broken baffle(s) or heatsheild rubbling...of course could be cats as well, but I'd bet on the aftermarket install in this case
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 07-04-2016, 09:23 PM   #6
The Blue Angel
The Blue Angel's Avatar
Drives: 2014 BRM 1SS/RS
Could be the exhaust pipe hitting the tunnel brace. It happens on my Camaro!!
2014 Blue Ray Metallic 1SS/RS
A Road Warrior
The Blue Angel is offline   Reply With Quote
Old 07-05-2016, 12:19 AM   #7
angryv6
Lake Erie Monster
angryv6's Avatar
Drives: 02 Hyundai Santa Fe and 13 300
Exhaust rattling against the heat shield or tunnel brace, loose connections.
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS!
angryv6 is offline   Reply With Quote
Old 07-05-2016, 11:33 AM   #8
skongolf
I am assuming the heat shield is above the cats or x pipe. If it is hitting or rubbing is there a fix for it?
Old 07-05-2016, 12:45 PM   #9
drew peacock
Drives: 2012 2SS INFERNO ORANGE
and mine on real big bumps
drew peacock is offline   Reply With Quote
