10-02-2017, 11:14 AM | #29 | |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
A Sprint Cup car makes around 500hp with a restrictor plate and they max out around 190mph by themselves (no draft) and they are about 4-500 lbs lighter and more aerodynamic. |
10-02-2017, 06:33 PM | #30 |
You are wrong, the 6th-gen SS most definitely does have a speed limit of 180 set in the ECM. Multiple people have read the tune files of 2016 and 2017 cars, including myself.
10-02-2017, 06:46 PM | #31 |
Owned gen 4, 5 and 6
Drives: 2017 Camaro 2SS Join Date: Jul 2017
I had mine at 170 and it was still going up, very slowly though. I do have the cold GM air intake which may give it an extra mile or two faster at those speeds.
2017 2SS, Mosaic black <3, NPP Exhaust, MRC, GM CAI, Loaded.
10-02-2017, 06:49 PM | #32 |
Drives: 2016 SS Join Date: Mar 2016
Don't know what top speed might be other than Chevy's literature that says 180. I have no reason to doubt that since I've had mine at 160 and it was still gaining pretty fast.... however in all honesty, I was on a slight downhill slope and a very smooth road. I would think wind might start winning the battle at around 170 on the flat, and 180 would take a very long road.
10-03-2017, 10:37 AM | #33 | |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
lol. ok.... so the GM people aren't telling the truth? the GM brochure's are lying and most important, since we are a suppler of the Camaro line, my inside sources are lying too? I have also read the file when my car was being tuned with HP tuners. I didn't see anywhere in there that said that. If you can supply proof that, its the case. I'll gladly crawl in a hole and apologize. (not meaning that in a rude way). your right..
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
10-03-2017, 05:52 PM | #34 | |
10-03-2017, 07:55 PM | #35 |
HYPER SS
well then.
that's all new news to me. I apologize. I've been told by a number of GM people that it was drag limited and that it didn't have a limiter on them. I also thought that when they did an open talk with Al, he confirmed that it didn't have one. That's ok, not like we will ever go that fast on public roads anyway. So were you able to remove or raise the limiter then?
Ordered: 1/15/2016
10-04-2017, 04:09 AM | #36 |
I don't know what the drag limit is, might be there, might not. Interesting that the 'governor' exactly matches what the brochure lists for top speed of the SS Coupe though.
10-04-2017, 07:36 AM | #37 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
09-21-2019, 03:27 AM | #38 |
Drives: 2021 ZL1 6MT Join Date: Jan 2017
Judging from the rate of acceleration...
09-21-2019, 04:56 AM | #39 |
Drives: 2017 SS 1LE Join Date: Mar 2017
See link and YouTube. Official timing just under 173. It simply runs out of power to over come aero drag, it hits the wind wall... Not sure how others got to 187, maybe... But I paid 2k to run it on the space shuttle landing strip, which is 3 miles long and very smooth.... Stock 1SSLE and my foot was down to the floor...
https://m.youtube.com/watch?v=cje5Wj7jBUU https://www.camaro6.com/forums/showthread.php?t=528885 Last edited by Timbo-1LE; 09-21-2019 at 05:17 AM. |
09-21-2019, 06:57 AM | #40 | |
BTW kudos for supplying some real tested data. |
09-21-2019, 07:11 AM | #41 |
Agree the tires would impact wnta1ss, it's sooo slow pulling the last few hundred rpms... Not sure if it would pull the last 400 with more road, what the mph would be, 180 probably, over that, suspect... as you would be at redline.
09-21-2019, 07:12 AM | #42 |
Drives: 2017 Camaro SS Join Date: Nov 2018
Until I can get to some wide open spaces out west I'm content with having hit the ton. Over 100 MPH on NJ roads is just plain a bad idea.
Kevin
Luceo Non Uro |
