Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 06-19-2015, 09:47 PM   #1
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
Will a stock ZL1 A6 dead hook at the drag strip with stock Goodyears
If you have to use drag radials, what size tire, wheel, and air pressure work?
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
Old 06-20-2015, 10:36 AM   #2
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
For 99% of drivers Goodyears will not hook with a stock ZL1
Any drag radial will hook a stock ZL1
Trackman is offline   Reply With Quote
Old 06-20-2015, 02:28 PM   #3
ihada69L78
ihada69L78's Avatar
Thanks!
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
Old 06-20-2015, 09:38 PM   #4
white ZL1
Drives: none
On an incredibly well prepped track, the fastest stock guys are dead hooking the factory tires.
No idea how though.
white ZL1 is offline   Reply With Quote
Old 06-21-2015, 10:09 PM   #5
big dave
Drives: 2017 ZL1
My stock ZL1 has pulled a few 1.6 60' times with a best of 1.65. So to answer your question...yes the stock tires can hook. They need a lot of heat in them and a well prepped track.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 06-22-2015, 06:54 PM   #6
ihada69L78
ihada69L78's Avatar
What tire pressure and launch RPM are you using?
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
Old 06-23-2015, 04:38 PM   #7
big dave
Drives: 2017 ZL1
Tire pressure between 30 - 31 psi. I generally put a slight load on the converter...perhaps 1k rpms. It all depends on the track and the conditions. It may take a few passes to get the feel before a perfect run.
Old 06-23-2015, 09:08 PM   #8
ihada69L78
ihada69L78's Avatar
Thanks!
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
Old 06-25-2015, 01:07 PM   #9
camarovigoa
Drives: 2013 Camaro ZL1 Victory Red A6
Leave all the traction c ontrol on you'll dead hook.
camarovigoa is offline   Reply With Quote
Old 08-17-2015, 08:32 PM   #10
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
doesnt traction control limit somethings?
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 08-17-2015, 08:46 PM   #11
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
Yes, traction control can limit and/or reduce the power your putting to the ground. Many times the traction control is better than the driver or available traction so you will get better ETs with it. The best ETs FOR A given combination are generally run without TC.
NicKey is offline   Reply With Quote
Old 08-17-2015, 10:25 PM   #12
climb-101
Drives: 2010 2ss
dead hooking is a bad thing, it breaks parts and pulls the RPM down too much for a good launch. you need some wheel spin to have a good launch.
climb-101 is offline   Reply With Quote
Old 08-17-2015, 10:35 PM   #13
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
The only truth to this is dead hooking breaks parts.
No car picks up et from spinning. It may pick up mph but that's it.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 08-17-2015, 10:56 PM   #14
climb-101
Drives: 2010 2ss
I disagree, ever watched pro stock cars leave the line. they tune and change how much wheel spin they have to get that fine line between pulling the RPM down too much and running a slower 60 and spinning too much and running a slow 60'
