Old 02-09-2020, 08:34 PM   #1
RedlineSS18
Drives: 2018 2ss redline
First drive after installing the Magnuson 2650 on my SS
I spent the better part of a weekend installing the kit I purchased. I found the kit to be extremely well made and fairly easy to install with the right tools and some mechanical ability. The instructions were slightly off as Magnuson provided a different fuel line than depicted in the manual but it was an improvement. Today I took it out for its first spin. This thing is a rocket when you jump on it and feels nearly stock during normal conditions. My only complaint is that I couldn’t hear and whine but assumed that could be the case with a blower that spins so slow for my application.
Thanks for all the people who posted their experiences on the forum it made my installation much easier!
RedlineSS18 is offline   Reply With Quote
Old 02-09-2020, 10:00 PM   #2
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Who did the tuning?
Old 02-09-2020, 10:32 PM   #3
RedlineSS18
I used the tune from Magnuson that came with it.
Old 02-09-2020, 10:51 PM   #4
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
Congrats, your going to have lots of fun with it.
Stefano is offline   Reply With Quote
Old 02-10-2020, 07:31 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
They are pretty tame, you have to spin them harder for sure. You'll still enjoy sneaking up on them and then they'll know what you have after they see some tail lights. Congrats.
Old 02-10-2020, 12:03 PM   #6
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
congrats! may I make a suggestion. get it re-tuned with HPtuners. While the maggie tune is "ok" i found that it runs richer. by getting it tuned i was able to unlock about 30 more HP, but more important the car A/F is right where it needs to be and happy.
2) yes my only complaint was the whine factor as well. I've searched and asked opinions but no dice.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-10-2020, 12:10 PM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Eaton tunes these rotor packs for OEMs, and most OEMs want refinement, which means very little noise. I bet you won't find much whine until you're well-into the teens in boost.
'20 ZL1 Black "Fury"
Old 02-10-2020, 12:58 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My Whipple is also fairly quiet, but one thing that did help was removing the rubber seal across the top of the Rotofab box. I can hear a little more Whine since doing that. I basically removed the seal because it was causing my hood to not sit flush. So in the process I noticed I can hear a little more whine in the car. I also Haven't noticed any adverse effects in my data logs from not using the seal.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-10-2020, 02:03 PM   #9
Tim M
Drives: 2018 Camaro SS 1LE
First drive should be awesome - glad it didn't disappoint!
Tim M is offline   Reply With Quote
Old 02-10-2020, 05:26 PM   #10
BlaqWhole
Ok that gives me some peace of mind to know that the Magnuson tunes are pretty good. I know some of these companies put out some really terrible tunes. I'm glad that thing is moving!! Any plans to get it on a dyno?
Old 02-10-2020, 09:39 PM   #11
RedlineSS18
I have the gm performance intake and another member recommended removing the air box lid. I took it out again today and it might have made a small difference but who knows for sure.
Old 02-10-2020, 09:41 PM   #12
RedlineSS18
The Magnuson tune does utilize HP Tuners. Ill probably wait to get a custom tune when I upgrade the fuel system and add long tube headers.
Old 02-10-2020, 09:42 PM   #13
RedlineSS18
The tune does seem pretty good but I’m sure leaves some on the table. Yesterday the trans (A8) seemed to be hunting a bit but seemed better today. The factory tune does not adjust the trans.
Old 02-10-2020, 10:02 PM   #14
laynlo15
laynlo15's Avatar
Our tunes normally don't change the TCM, its just not usually needed as the factory tunes are pretty decent. It usually opens up a new can of worms when you start messing with the torque management and pressures.
