dave@hennessey
Old 11-25-2013, 10:05 PM   #1
DarkneZZ
DarkneZZ's Avatar
Drives: '13 Camaro 2LT/RS
Hood Color Faded..=/ wtf
Hey, guys.
So I had my hood, roof, spoiler and gascap plastidipped about 4 months ago.
A week ago I decided to go with a different look and peeled everything off.
Color of the hood and gascap faded, but roof and spoiler remained the same.
Plastidip was applied correctly, it peeled off instanteously.
I am really worried that the color is going to stay like this and you can really see the difference. Any suggestions on how to fix that? Maybe it may be covered under warranty? :S
DarkneZZ is offline   Reply With Quote
Old 11-25-2013, 10:07 PM   #2
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
hmm, maybe the other body panels faded instead of the dipped parts ?
or maybe the dip left residue or stained the parts ?
LIM3 is offline   Reply With Quote
Old 11-25-2013, 10:10 PM   #3
DarkneZZ
DarkneZZ's Avatar
Maybe, but if you look on the second picture, the white color of the body is more "summit white"ish than the hood. Hood looks almost yellowish.
I tried washing it, waxing it, leaving it on the sun...doesn't seem to work
Old 11-25-2013, 10:14 PM   #4
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Clay bar the hood and gas cap to remove everything then start buffing, polishing, waxing and sealing. If that doesn't work. Your only option is to have it color sanded and re cleared or re painted and cleared. It's possible the chemicals stained the clear.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 11-25-2013, 10:21 PM   #5
LIM3
LIM3's Avatar
Drives: SGM
yeah i agree. try claying it,polishing and maybe even tar x. hopefully its not permanent staining. i wonder why no one else has noticed this on their SW camaros.
Old 11-25-2013, 10:26 PM   #6
DarkneZZ
DarkneZZ's Avatar
I claywaxed it, but still the same.
How much do you think it would cost? Why roof and spoiler didn't change in color then?
Old 11-25-2013, 10:29 PM   #7
LIM3
LIM3's Avatar
Drives: SGM
maybe those two areas where the result of a spray can that was not "shaken" long enough ?
im really curious as to why this happen.
OH AND maybe you can try wet sanding the affected areas.
Old 11-25-2013, 10:51 PM   #8
DarkneZZ
DarkneZZ's Avatar
I really don't want to do it myself as im afraid I might mess it up.
If i go to auto detailing shops, do you think they might help me with that matter?
perhaps the worst case scenario is to buy a new hood, which is like what, $800?
Old 11-25-2013, 10:54 PM   #9
STuRTzz
Drives: '12 Summit White 2ls W/Black Stripe
Don't panic. "Staining" does happen to some cars with plasti dip. What color did you plasti dip it? They don't know what causes it to stain but it usually goes away in 1-2 weeks with the sunlight. Best thing to do is just let it bake in the sun for a week or two and see if it gets better.
STuRTzz is offline   Reply With Quote
Old 11-25-2013, 10:54 PM   #10
LIM3
LIM3's Avatar
Drives: SGM
a detail shop can assist but dont buy a new anything. just have it repainted by a good shop IF the wet sand step fails to fix it.. your car being a solid color with no metallic flake is pretty easy to match and get right the first time. A fresh paint job on those areas shouldn't be more than $400
THIS IS MY 5K POST. WOOT WOOT !
Old 11-25-2013, 10:55 PM   #11
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Sorry to see tha, It's pretty obvious. I hope you get it fixed cheap.
11TexaSS is offline   Reply With Quote
Old 11-25-2013, 10:57 PM   #12
LIM3
LIM3's Avatar
Drives: SGM
that is great news
Old 11-25-2013, 11:07 PM   #13
STuRTzz
Make sure you don't start wet sanding it until the 2 week mark is over. Im on the DipYourCar forum a lot of this does occur. It is weird how only hood stained. Also did you dip it yourself or did a company dip it?
Old 11-25-2013, 11:09 PM   #14
DarkneZZ
DarkneZZ's Avatar
phew! that's what I thought. I will try to keep it under the sun. Thank u!
