TireRack
Old 04-24-2024, 12:29 AM   #1
SS_CTS-V
Drives: 2015 SS, 2006 CTS-V (wrecked...)
Cam swap, now low oil pressure…
Damn the luck! Guess I pinched the oring when installing the new oil pump the second time… Looks like I’ll be going back in there to put a new oring on. I only have 15psi at hot idle. Not tuned yet, just initial start up. So maybe 600 rpm, but since I installed a Mellng 10295 and fresh oil, darn should have better than 15psi.
Not looking forward to ripping it all apart again.
SS_CTS-V is offline   Reply With Quote
Old 04-24-2024, 01:06 AM   #2
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
If you remove the oil pan completely, you can install the pickup tube carfully and not gamble on the O-ring pinching.
To be able to remove oilpan engine still in the car, I cut the small crossmember off and made flanges to it to be bolted back on.
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual.
1978 Blazer offroader with LS1, 1-ton axles.
Tommi is offline   Reply With Quote
Old 04-24-2024, 06:27 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Does your engine have vvt?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-24-2024, 10:57 AM   #4
SS_CTS-V
Nope, standard LS3. No VVT or DoD.
Old 04-24-2024, 11:42 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well that bites!! I have the 10295 in my engine, and at hot idle mine shows 34-39psi with 5w30 mobil 1, and around 54-55psi at cruising speed and rpm. 65-68 at wot.. Not sure which spring they installed in the pump when it was installed. I know it comes with an extra one. Good luck, hope you get it fixed..
1JEWLDSSRS is offline   Reply With Quote
Old 04-24-2024, 02:09 PM   #6
morepowerjoe
The reason I ask is when I changed my pump the second time I went with the 10295 and my pressure went down to 15 psi. It was because I have an l99 with vvt and it has a high-volume pump and when I went with the 10295 it is a high-pressure standard volume. So, then I changed it out back to a high-volume pump and my pressure was back to normal. I know this probably doesn't help just thought I would through it out there.
Old 04-24-2024, 11:24 PM   #7
SS_CTS-V
Appreciate the comments from you all. I hope to have another go at this over the weekend. Fingers crossed a new oring fixes it. If not I’ll probably order another pump and try again.
