Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 01-16-2017, 09:36 AM   #1
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
notchy shifter
I ordered my 2012 2SS with a Hurst short throw shifter. It's really notchy and not smooth at all. Would changing the shifter to a different brand, solve this issue? Or, is it just the nature of the beast with the six speed?
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
scott's45 is offline   Reply With Quote
Old 01-16-2017, 10:58 AM   #2
djcfuzz
Do somethin fun every day
djcfuzz's Avatar
Drives: 2012 45th V6 RS M6
Hi, the only full shifter replacement I am aware of that is available is the MGW. It is my understanding that all others are just a "stick". I did my MGW install myself and had the opportunity, with the help of a friend's lift, to see how the shifter ties into the transmission. It is a well built piece of hardware. I really like the feel of this shifter. The shorter throw reminds me of my old M-22 that I had in my 1967 Firebird. My stock shifter went from what I would call "sloppy" to "smooth" with the MGW. There are some good threads on here with install info.
djcfuzz is offline   Reply With Quote
Old 01-16-2017, 01:03 PM   #3
scott's45
Scott's45
scott's45's Avatar
Thank you, appreciate the info.
Old 01-16-2017, 02:19 PM   #4
djcfuzz
djcfuzz's Avatar
I see we both have 45th's. Mine is a V6 and that you have the V8. So different transmission and the MGW is built a little different to link up, basically the same hardware inside so there should be no worries. I put dynamat underneath on the tunnel after installing the MGW and some more in the cabin by the shifter prior to putting in their noise deadening material. Also, I used the stock shift knob to keep with the 45th style. I see you have the SS ball knob, looks good.
Old 01-16-2017, 07:08 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I don't think a shifter change will fix your notchiness, the reason I say that is the shifter is just a stick and ball on a pivot now tightening the stocker could help, I ordered a Pegasus Machine poly billet rear mount and it seemed to help a lot and for less than a hundred bucks it beats a aftermarket 300.00 shifter.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 01-18-2017, 05:58 PM   #6
djcfuzz
djcfuzz's Avatar
https://www.mgwshifters.com/shifters/camaros/82
Old 01-18-2017, 08:24 PM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
What do you mean by "help a lot" .... reduce notchyness, slop, NVH ?
camguynj is offline   Reply With Quote
Old 01-18-2017, 08:39 PM   #8
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
Why not try the ZL1 shifter upgrade?
rich2342 is offline   Reply With Quote
Old 01-18-2017, 11:13 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Fix
Seemed to fix some the notchiness and slop and didn't really get a increase or decrease in NVH, it just feels more positive. I have a 2010 with a factory Hurst installed just not factory installed.
Orange Krush II
Old 01-19-2017, 08:04 AM   #10
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
I have run 3 different shifters on my 2010. stock, MGW, and GM factory Hurst. The shifter change will not help. It is a fluid change that makes the most difference.
Get 4 quarts of Mobil 1 SYNTHETIC ATF (be sure to buy the one designed for OLDER vehicles that originally used Dexron 3 ATF).
Drain fluid then fill with a funnel and 4 feet of rubber hose from the top of the engine compartment. Cheap and easy.
Stingr69 is offline   Reply With Quote
