Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 05-09-2012, 05:20 PM   #1
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
V-6 Fuse Pull?
Is there a fuse that I can pull on my v-6 where is re-sets the driving memory of the computer?
My reason for asking is that I am curious if this will help improve some performance/gas mileage.
I traded in a Dodge Magnum with a V-6 and that had one, wondering if the LFX has the same.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 05-09-2012, 07:27 PM   #2
theragtopguy
Lifetime Philly Fan
37 views and nobody has an answer for me?
[/SIZE]
Old 05-09-2012, 07:30 PM   #3
NFERGY 2011 RJT
NFERGY 2011 RJT's Avatar
Drives: 2011 2LT RJT
i would like to know that also
NFERGY 2011 RJT is offline   Reply With Quote
Old 05-09-2012, 07:31 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
There is no fuse pull for the V6. It is not needed
Click to view my build thread
The Stig is offline   Reply With Quote
Old 05-09-2012, 08:03 PM   #5
Chef Camaro
Cooking is My Life.
Chef Camaro's Avatar
Drives: 2012 1LS
The LFX is a hot mess right now, with very minimal upgrades it's been a fun time searching in forums and different websites trying to figure out mods. As for aesthetics though it's as easy as pie.
Live to Cook
Cook to Live
My Build Thread
http://www.camaro5.com/forums/showthread.php?t=222338
Chef Camaro is offline   Reply With Quote
Old 05-09-2012, 08:26 PM   #6
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
There is no fuse pull on the V6 Camaro as stated. If you have the 20" Pirelli then your car's gov is set at 155. Here is a link to a silver camaro v6
http://www.king5.com/news/local/Bran...150757755.html
Ir0nM4n is offline   Reply With Quote
Old 05-13-2012, 06:45 PM   #7
Wizzer
Drives: 2010 Cyber Grey
From reading I get this....... Pull the cable off the battery and let it rest a while like that. Plug it back up and the computer relearns.... I do not know if that is actually what happens but I had a problem with my traction control after a burn out in wet weather and I had to do this to clear the light. My car felt like it had more pep after I put the cable on. Then gas spiked and I put the lower octane in and it lost the pep. Glad it's going down cause the v-6's like higher grade gas so the knock sensor doesn't retard the timing.
Wizzer is offline   Reply With Quote
Old 05-13-2012, 06:53 PM   #8
bmorecam
Drives: jealous vendors mad!! HAHA!!
fuse 5 and 20 in the engine bay will reset your ecm only. What this will do is reset knock sensor, fuel trims, TP, etc...at first it might feel like your car gotten faster but after about 100 miles when the learning process is 100% your car will be the same. our v6 bosch does not have high and low octane map like the v8. It adjust timing advance and knock sensor all on it's own according to the environmental condition(humidity, temp, etc)and octane, or cylinder pressure sensitivity and temperature. The ecm has the capability to read and monitor all of these things and adjust accordingly. bosch e69 is a very sophisticated exotic ecm known to be used in DI engines. Did you know Lamborghini use bosch ecm? LOL.
Sent using Shotta-talk
bmorecam is offline   Reply With Quote
Old 05-13-2012, 07:16 PM   #9
theragtopguy
Lifetime Philly Fan
Thanks, I understand.
[/SIZE]
