12-21-2021, 02:10 PM | #1 |
Drives: Chevy Camaro LT1, BMW M3 Join Date: Apr 2021
How does the LT1 do in snow with the all-seasons?
I'm thinking of taking my LT1 with the 245 all seasons skiing this season.
Is the car drivable in a few inches of snow? Where I go gets plowed but the there may be some snow and ice. I'd love to take the Camaro but I don't want to be a moron and get stuck. Curious to see if anyone has experience driving in light/moderate snow conditions with this set up. |
12-21-2021, 03:02 PM | #2 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
I don't drive in the snow, because it doesn't snow here. But it is bad enough just trying to drive the LT1 in the rain. Can it be done? Absolutely. Do I want to? Not at all, I don't enjoy having to feather the throttle even more so than in dry conditions.
12-21-2021, 03:24 PM | #3 |
Drives: n/a Join Date: Jul 2018
What’s the problem with driving it in the rain?
12-21-2021, 03:45 PM | #4 |
The tires spin the instant I require anything more than mild acceleration, regardless of traction mode. When its raining and im caught out there in the LT1, I am forced to drive like that very old person that you get mad at and overpass because they are driving under the speed limit. I rather use the daily if I know the weather is going to suck. I dont enjoy my LT1 anywhere near as much in bad weather. It is neutered in bad weather in my opinion. Dont get me wrong, these cars drive fantastic in the rain when compared to 4th gen fbodys or the older stangs, but I feel like the risk just ain't worth the reward trying to drive the LT1 in bad weather. All the other clear days and nights it's LT1 time.
12-21-2021, 03:46 PM | #5 |
Drives: 2021 Camaro 1SS Shock Vert Join Date: May 2021
I used to drive my IROC in the 80's with the standard tires. It's not optimal. you just need to get used to it.
But - low profile tires are not designed for the snow. Good snow tires are softer and tend to be taller and narrower. If you need to drive in the snow, find a set of steelies or base model 18s on eBay and buy and run 18 inch snow tires. I actually do that with my Chevy Cruze winter car. I pull the 18" LTZ wheels and tires and run 16 inch OEM wheels with snows. |
12-21-2021, 04:02 PM | #6 | |
(For the record, I did drive through nasty downpours on my OEM runflat Goodyears, which was a total pucker experience. Ended up doing 30-35 mph in the right lane with my hazards on, and every single SUV zooming by at 60-70... it's all in the tires.)
12-21-2021, 04:07 PM | #7 |
I wouldn’t think that it’s ideal, but It certainly can be done. Throw a couple 40lb bags of sand and a shovel in the trunk and head out. I’d be willing to bet that the Camaro handles much better in the snow than most rear wheel cars I daily drove back in the day.
12-21-2021, 04:18 PM | #8 |
Drives: 2021 LT1 Join Date: Aug 2020
I've switched from the runcrap tires to normal all-seasons on my LT1 and plan to drive it under almost any situation this winter (short of heavy snow that I wouldn't drive in anyway).
In my limited experience last winter, it handled fine when the mode set to Ice/Snow. |
12-21-2021, 04:27 PM | #9 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
I live in snow country and if I was ever going to consider driving my Camaro in the snow, I wouldn't do it with anything less then dedicated snow tires. Not even all seasons. I'd do what @Hotlap does.
12-21-2021, 04:35 PM | #10 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
A simple trick that applies equally to all generations of F bodies. If you drive it on the snow all seasons at a minimum. If you know snow is coming, fill the tank all the way and put a nice tool box, like 60-80 pound range in the trunk(securely) over the rear tires. You're welcome, it's not that hard really.
12-21-2021, 04:50 PM | #11 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I drove my 1LE home 900 miles in a major rain storm with the system set to wet/snow. So bad that I saw the system warning “no detectable traction” when it flash dumped as I was going 75 mph. I could feel the car float and then slowed to 55 mph and continued with no issues. 285 front, 305 rear summer only track tires. I drove every day all summer on those tires. I also drove 41,000 miles in 2016 and 2018 SSes. Half that on the 245 front, 275 rear summer only performance tires. No problem. I would drive the LT1 in light snow with 245 all season tires with no problem. That is the intent of those tires on that model. …like the I4 and V6 guys In the winter, I changed to winter tires, of the OE size, for all three. Again no trouble. -4500 density altitude so it makes way more power. I leave it in sport unless it’s snowing hard.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
12-21-2021, 04:56 PM | #12 |
Drives: My wife nuts... Join Date: Sep 2011
In the 70-80's all we had to drive was rear drive, non traction control vehicles.
I got around fine in 3+inches of snow. Imagine a dedicated slow tire with snow ice setting and abs. |
12-21-2021, 05:53 PM | #13 | |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
12-21-2021, 05:57 PM | #14 | |
Worse part IMO is that all the "wrong-wheel drive" guys seem to know that they have an advantage and come out of the woodworks. When I had my GTO I had a guy in an Eclipse take me off the line because I didn't want to spin. Probably one of the few times that wrong-wheel drive has a slight advantage. |
