10-30-2015, 03:07 PM | #15 | |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
My C6 has Bilstein shock and they are pretty stiff. (I'm quite positive it would be stiffer than M5's stock shocks) Comparing that to C7's stiffest setup, it felt very close at hard cornering, but still feels little more comfortable over the bumps. Advantage on MRC is, you don't have to go over bumps in that setup when you don't want to...
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd 1100: 7/27/15 <SSWNNN> 3000: 9/04/15 <TPW:10/19/15> 3800: 10/19/15 <VIN: 117740> 6000: 12/16/15 |
10-30-2015, 03:29 PM | #16 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
10-30-2015, 03:31 PM | #17 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
/topic.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-30-2015, 04:02 PM | #18 |
Drives: 2016 Z06/7. Join Date: Aug 2014
There's only 2 people I trust. One of them is me, the others not you.
10-30-2015, 04:58 PM | #19 |
SABIO
Is the Camaro MRC height adjustable?
10-30-2015, 05:32 PM | #20 |
KaBoom1701
No.
No need really for ride quality. You can add lower springs from the aftermarket gang.
Mods:
10-30-2015, 05:55 PM | #21 |
Drives: 2016 2SS Hyper Blue Join Date: Oct 2015
Ordered. 2ss with NPP, MRC... in black. over my budget but i am so hungry for this thing.
11-05-2015, 07:49 PM | #22 |
Drives: LS based beauties Join Date: Jun 2015
Bumping this, I want to order very soon.
NEVER have had MRC. I just want the suspension to be stiff and sporty. I'm not concerned with the bumps in the road. Is a non MRC camaro suspension as stiff/sporty as a MRC one? Seems like it's amazing for changing it for unforgiving roads but not really my concern with $$$ being tight. Also probably will be easier / available earlier to put on the chevy performance lowering kit (thought I saw that floating around on here) on when that's available? Thanks guys.
Planned order; Summit White 2SS, NPP Exhaust, Adrenaline Red Interior, Auto 8, 20" 5 Split spoke black, darkened fish tail lamps.
11-05-2015, 08:12 PM | #23 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
11-06-2015, 05:36 AM | #24 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
It's really for people who want a "one size fits all" suspension. Touring when cruising the backroads / highways; track when they're racing; sport for blasting down their favorite twisties / onramps. I do believe I read that the standard SS suspension fits in between "Sport" and "Track" on the MRC.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
11-06-2015, 06:30 AM | #25 |
Drives: Want a gen 6 Join Date: Jan 2013
Here in Texas we have shifting soil which makes bad roads. I would definitely get MRC.
11-06-2015, 06:59 AM | #26 |
Drives: 2016 Chevy Colorado Z71 Join Date: May 2015
Im on the fence. I think mag ride is worth it but i want the height adjustability of coilovers to dial in the perfect stance. Most lowering springs leave the car with a raked look and i want a level stance. Also while it is unlikely lowering springs will be an issue for mag ride, i have read at the limits they can be. Pdaft made a mag ride coilover conversion kit for the zl1 which would be perfect for what i want but not sure if the will exist for the 2ss.
11-06-2015, 07:44 AM | #27 |
Drives: 2016 2SS Join Date: Nov 2015
I was going to get it, but the more I think about I really don't care about it.
I will probably only put 4000 miles a year on the car so I'm sure I will be good without it. |
11-06-2015, 08:37 AM | #28 |
To each his own, just keep on mind you could easily spend more than 1800 on suspension upgrades later.
