Old 02-29-2016, 07:31 PM   #1
08z51c6
Drives: 2016 Camaro SS - A8, MRC, NPP
Wheel Spacers - anyone running them?
Rear wheels on my SS are tucked in a little too much for my taste. Looking at running a 3mm spacer to push them out a bit. Wondering if anyone has them and where you purchased them.
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
08z51c6 is offline   Reply With Quote
Old 02-29-2016, 07:35 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
using a 3mm spacer on the rear.. Ben at weaponX is a good source:
20 x 9 front - offset 15
20 x 10.5 rear -offset 35 + 3 mm spacer
Tires - 275/35/20 & 295/35/20
Old 02-29-2016, 07:49 PM   #3
08z51c6
Awesome, Thanks!
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
Old 02-29-2016, 09:07 PM   #4
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Originally Posted by 08z51c6 View Post
Awesome, Thanks!
Hi. Running a 3mm spacer won't really do much.
Glens look is acheived by running an offset that pushes the rim out about 16mm front and back.
He added the 3mm in the back for flushness with the fender.
If you want to push the stock rims out you will need something like
10mm - 15mm. But then you get into Hub spacers, the ones with studs attached.
It is something I am.looking into as well.
Old 02-29-2016, 09:33 PM   #5
08z51c6
Thanks for the feedback.
I'm not looking to duplicate Glen's look, just want to push the wheels out a tad. I realize they will still be inside the fender and I'm ok with that. I plan on going with a slightly larger all season tire so the combo of the two should be much better than the sunken in stock look.
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
Old 03-13-2016, 06:19 PM   #6
Camaro36
Drives: Camaro 2SS
keep us posted with what you go with. Im thinking about getting some as well for the rear (maybe 15mm) but not sure yet.
Camaro36 is offline   Reply With Quote
Old 03-18-2016, 03:03 PM   #7
Cal602
Cal602's Avatar
Drives: 2016 Camaro 2SS Summit White
post pics if you could!
Cal602 is offline   Reply With Quote
Old 03-18-2016, 03:41 PM   #8
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
I put 25mm on mine all around on the factory wheels, looks pretty aggressive, tiding me over till wheels come in...
Team STILLEN is offline   Reply With Quote
Old 03-18-2016, 04:03 PM   #9
NITRA10
NITRA10's Avatar
Drives: 16 Camaro SS
PICS PLEASE!!!!!!!!
NITRA10 is offline   Reply With Quote
Old 03-18-2016, 04:27 PM   #10
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I think my guy that sells me wheels had good advice; buy the offset that gets you as close to the look you want, then a small spacer to dial it in perfect. That way you can use stock lugs and have enuf threads left for safety. We just did that on my new wheels, on rears, the fronts were perfect with the wheel offset.
Old 03-18-2016, 07:56 PM   #11
BradfordCamaro
SABIO
I'm trying to get going on my wheel spacer project....but I am working 7 days right now. What little time I have I try to be a dad to my 3 boys.
I also am planning on some rims with a moderate push out and like Glen mentioned, it leaves room to tweak the final fitment with some thin spacers.
I would like to have this done yesterday......most likely a few weeks.
Old 03-18-2016, 09:45 PM   #12
Camaro36
Drives: Camaro 2SS
Pictures PLEASE?
Old 03-21-2016, 06:50 PM   #13
Camaro36
Drives: Camaro 2SS
Bumping for some pictures
Old 03-21-2016, 07:21 PM   #14
08z51c6
Haven't done anything with my car yet, will prob be doing the spacers first then the tires due to cost.
Current Vehicle:
2001 C5 Corvette
Previous Cars:
2009 C6 Z06
2008 C6 Z51 PKG
