08-21-2016, 07:37 PM | #1 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Aerodynamics without stock style muffler
Anyone else concerned that removing the stock style muffler module and replacing with small mufflers on each side (ie. similar to GMPP's Borla setup and all other aftermarket setups), could result in less favorable aerodynamic properties? At the factory fest, they had a camaro displayed on it's side with the GMPP exhaust and you can see this huge empty space where the stock muffler was and the rear bumper comes down fairly low. I'm a little concerned that would disrupt air flow at higher speeds. The stock muffler at least appears that it would smoothen air flow in that region.
08-21-2016, 10:08 PM | #2 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
I would worry about the rear diffuser if a person swaps exhaust to something that doesn't fill the void in similar fashion.
08-21-2016, 10:51 PM | #3 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Not to worried about it, I have not been to the track yet and not even sure if I will get on the track to worry about high speed air flow. On the plus side, the stock exhaust weighs a ton, better gas economy when you get that weight off and maybe a sound you really like. Not that the Camaro stock sound is bad, it's great.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
