Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Specific Models / Packages > Camaro Convertible Forum
Old 01-07-2011, 10:46 AM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Thumbs up First 2011 Camaro Convertible Review (by Motor Trend)!
Via http://www.motortrend.com/roadtests/...#ixzz1AMthvzQT
First Test: 2011 Chevrolet Camaro Convertible
How to Build a Better Camaro: Cut Off the Roof
From the March, 2011 issue of Motor Trend
/ By Scott Evans
/ Photography by Evan Klein
Oh come, ye armchair engineers. Tell us that removing a stressed member as important as the roof is bad. Regale us with stories of chassis flex and cowl shake.
We will listen. Then we will politely disagree and point to the 2011 Chevrolet Camaro Convertible as evidence. Counterintuitive though it may be to the number crunchers, cutting off the roof has made the Camaro a better car.
Of course, Chevrolet didn't simply Sawzall-off the roof and kick the Camaro to the showroom. If you'll recall, the original Camaro Convertible Concept debuted four years ago, a year to the day after the original Camaro Concept. A topless car was always in the cards, but then, so was bankruptcy.
After multiple delays, sun worshipers will finally be able to buy Camaro Convertibles very soon. And what a happy crowd it'll be, because the convertible takes everything good about the Camaro and amplifies it. It looks better, sounds better, and is a better car to drive, all of which is directly attributable to the new hat.
Sure, the engineering business is difficult, but really the hardest part of designing any convertible is making it look good. We all remember the old Nissan 350Z and Audi A4 convertibles, cars that were obviously not originally intended to be seen without their roofs.
Getting the roof of the Camaro Convertible to look right was a massive undertaking given the car's eccentric design, and Chevrolet pulled it off. In fact, it looks better than the coupe. Where the coupe's roof is pulled in tight over the big, flat rear fenders, the convertible's roof meets the haunches more naturally and better fills the space on the rear deck. Folded, the cloth roof hides nicely below the Coke bottle fenders and can be covered by an optional tonneau that, frankly, isn't worth the effort or the estimated $200 price tag. (To be fair, though, it's marginally better than the Mustang's cover.) Hiding the AM/FM antenna in the new rear spoiler is a neat trick, and the effort put into keeping the roof looking smooth and not like an emaciated horse is noticeable and appreciated. For now, that roof is available only in black and tan, but Chevy hinted to us that other colors could be offered down the road.
Naturally, ridding yourself of the roof greatly improves outward visibility. What's more impressive is that, even with the roof up, the Camaro Convertible is easier to see out of than the coupe. As you'd expect, the rear window is far smaller on the convertible, but you'd be hard-pressed to notice the difference in actual visibility.
It's simply more forgivable since it's a drop-top. Over your shoulders, the deletion of the thick B-pillars makes lane changes a far less panic-inducing endeavor. Rear-seat passengers will appreciate that the quarter windows even roll down now.
There's still the issue of forward visibility, though. As the coupe and convertible are identical from the windshield forward, those massive A-pillars are still there, necessary for rollover protection, and they'll do everything they can to prevent you from looking through the corner. Meanwhile, the massive OnStar-equipped rearview mirror will do its best to block your view to the right.
Once the wind is in your hair, you won't care. To go topless, grab the single center-mounted latch, pull it down, and give it a twist to the right. Then simply push and hold the nearby roof-control switch and the car will do the rest in about 16 seconds. If you checked the appropriate boxes, you can then affix the optional tonneau cover and a folding wind deflector, the latter of which will forfeit the rear seats, both of which will take up space in the already downsized trunk. To make room for all the necessary roof parts, trunk space drops from 11.3 cubic feet in coupes to just 10.2 in the convertibles. Fold the roof, and you're left with only 7.9 cubic feet of space. As in the old Cadillac XLR, a pull-out screen protects the soft roof from your cargo, which you can stash under and around the folded roof, after you get it through the same tiny trunk opening.
Putting the roof back up is a bit more of a chore. If you've got the tonneau cover in place, that's got to go back in the trunk. Then the roof needs to come up, and it's a much slower process in reverse; in our tests it took about 25 seconds to get the roof up and latched and the windows closed. Short traffic lights and heavy downpours will be your enemies. They certainly were ours. Our early build tester arrived during what's been called the "storm of the decade" for Los Angeles and, naturally, the roof leaked in two places along the windshield header. As if that wasn't enough, the rear window decided to dislodge itself from the soft top. Is this really the same top supplier that builds the Corvette Convertible's roof?
Such is the price of any convertible, if not typically so costly. The price you won't pay is in chassis rigidity. No, numbers people, it's not as rigid as the coupe and we never expected it to be. Chevrolet's engineers are eager to boast, however, that it is stiffer than a vaunted BMW 3 Series convertible. They have to disclose, of course, that it took more than little blue pills to get the job done.
The Camaro Convertible features new V-braces under the front and rear of the car, a new transmission brace, a new front shock tower brace, and a new sheer panel below the driveshaft. All the bracing, along with the various folding roof parts, adds some 253 pounds to the curb weight of an already hefty car. On the plus side, it does help shift the weight balance rearward slightly and closer to a 50/50 split.
Good news is the difference isn't noticeable from behind the wheel. The Camaro coupe always felt a bit too heavy going down the road, and we're happy to report the convertible isn't any worse. In fact, Chevrolet says it's been working on the Camaro's handling, and both the convertible and the coupe have revised damper settings for better on-center feel and less understeer. Those damper changes don't do much to affect the ride, which is still rather firm as befits a sports car. To our fingers, the convertible's steering had a bit more heft and better communication with the tires than the last coupe we drove. It's just too bad you still have to feel it through that uncomfortable, overstyled steering wheel.
The real effects of the weight gain and chassis modifications can be found on the track. Our V-8-powered SS model hurled itself to 60 mph in 4.9 seconds, 0.2 second slower than the last SS coupe we tested. The ragtop followed up with a 13.2-second quarter-mile sprint at 109.2 mph, just behind the coupe, which did the deed in 13.1 seconds at 110.8 mph. Sixty-to-0 braking took just 107 feet, one foot shorter than the lighter coupe's 108-foot performance. On the skidpad, the convertible was able to pull 0.89 g, a bit worse than the coupe's 0.93 g, and ran through our figure-eight course in 25.9 seconds at 0.61 g compared with the coupe's 25.2-second lap at 0.73 g.
We might have to give a small amount of thanks to that weight gain. The convertible feels more planted on the road than the coupe, and more deliberate in corners. The extra bracing earns its keep when the roof is down, with little noticeable chassis flex or cowl shake. The car just feels solid all the way around, not flimsy like convertibles of F-Bodies past.
Confidence in the ride allows you to better enjoy the experience. Chevy says it hasn't touched the exhaust, but everyone here thinks the convertible is louder and nastier than the coupe. But it's likely that thin top letting in more noise, and that's not a complaint.
The tradeoff is increased road and wind noise, but we'll take it. We didn't have a chance to sample the optional wind deflector, but we could live without it. We're also happy to report that interior measurements have changed by only fractions of an inch, so friends you stuff into the back won't suffer any more than they would otherwise.
The Camaro Convertible may be fashionably late to the game, but the timing couldn't be better. In 2010, the Camaro finally bested the Mustang in retail sales for the first time in 25 years, but the buzz has begun to wear off a bit, allowing Mustang to catch up in monthly sales.
It's admirable that the Camaro hung onto the lead this long, really, with only a coupe to go against Mustang's coupe, convertible, and GT500. Now, Chevy intends to level the playing field with the convertible and upcoming Z/28.
It may not be that simple, though. Camaro Convertibles will be available only in the LT and SS trims, not the base LS trim. This means prices will start at $30,000 for a V-6 and $37,500 for a V-8, some $2000 more than V-6 and V-8 Mustang Convertibles. Will it hurt sales? Probably not, as Camaro coupe buyers have already been paying $500 more to start than Mustang buyers.
Being a better car than the Camaro coupe certainly won't hurt either.
Read more: http://www.motortrend.com/roadtests/...#ixzz1AMthvzQT
Tran is offline   Reply With Quote
Old 01-07-2011, 10:59 AM   #2
.... Gorgeous!....
Certainly is another Big Win!
Old 01-07-2011, 11:00 AM   #3
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Nice write up. I still can't get into the vert though. Maybe it'll grow on me.
WadeWilson is offline   Reply With Quote
Old 01-07-2011, 11:07 AM   #4
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Very good read, I'd like to see what that strut tower brace looks like.
Old 01-07-2011, 11:12 AM   #5
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
Nice write-up, hopefully they address the roof concerns in there.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 01-07-2011, 11:21 AM   #6
Murph0408
Murph0408's Avatar
Drives: 2LT Black '10 Camaro, 2000 Durango
good read. pricey though
Murph0408 is offline   Reply With Quote
Old 01-07-2011, 11:22 AM   #7
Tran
Administrator
Tran's Avatar
Here you go, from our LA autoshow photos:
Full set @ http://www.camaro5.com/forums/showthread.php?t=115987
Old 01-07-2011, 11:23 AM   #8
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Wow! Amazing that MT gave the vert such a good review! Their reviews of the coupe, both v8 and v6, are usually full of dislike, especially now in the new Mustang comparison tests! Way to go GM!
ssmike is offline   Reply With Quote
Old 01-07-2011, 11:30 AM   #9
LAWMAN
LAWMAN's Avatar
Drives: 2010 cam.2ss/rs.iom,07'escalade esv
nice,good looking car,im sure they will sell like hot cakes (as the saying goes)i plan to get the tower brace for my coupe,but not available yet
A9120159
1100:12/19/08
3800:06/19/09
6000:07/02/09
LAWMAN is offline   Reply With Quote
Old 01-07-2011, 11:32 AM   #10
LAWMAN
LAWMAN's Avatar
oh,and paint the tower brace inferno,of coarse
A9120159
1100:12/19/08
3800:06/19/09
6000:07/02/09
Old 01-07-2011, 11:39 AM   #11
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Tran delivers!
Those cast ends look a little rough, but nice looking piece overall. It's non-intrusive. I like.
Old 01-07-2011, 11:43 AM   #12
EnfuegoZ28
EnfuegoZ28's Avatar
Drives: 2000 GMC Sonoma
I can't wait to see a Z28 convertible!
EnfuegoZ28 is offline   Reply With Quote
Old 01-07-2011, 11:46 AM   #13
midnighter
Drives: nothing
omg
midnighter is offline   Reply With Quote
Old 01-07-2011, 11:49 AM   #14
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
They look great with the top down but in my life the top would be up more than down so I'll stick with my coupe.
Tori
click the sig pic to view my build thread
heRS is offline   Reply With Quote
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
New Camaro Convertible Blends Top-Down Driving Fun With Precise Engineering JoeP@TeamBeckyD Camaro Price | Ordering | Tracking | Dealers Discussions 1 11-28-2010 04:08 PM
