Old 10-01-2013, 02:25 PM   #1
parkermoeder
parkermoeder's Avatar
Drives: 2011 Camaro ss
help with steerung wheel shake
okay so i got my zl1 replicas from factory reproductions installed the other day. btw while they were balancing my tires they scratched ome of the rear rims(post pics later) and now sometimes i feel like the car is pulling one way or the wheel is slightly shaking. i gave it some gas on a on ramp and got it up to 90 and the wheel was shaking maybe a half inch back and forth and it never did this before. are the wheels bad? or do i just need an alignment? or possibly something else
edit: why my phone post pics sideways and only one of them i will never know. will fix when i get home
[2011 Camaro 2ss L99
-OEM Painted GFX
-Borla Atak axle back
-Stainless Power headers
-Cold Air Inductions Intake
-Blue oracle halos
-Satin black ZL1 replicas
-315 invos and other cosmetic mods
parkermoeder is offline   Reply With Quote
Old 10-01-2013, 02:28 PM   #2
parkermoeder
heres pic with new rims
edit: and theyre still sideways -.-
-OEM Painted GFX
-Blue oracle halos
Old 10-01-2013, 02:32 PM   #3
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Out of alignment does not cause wheel shake, improper wheel balancing will cause wheel shake. You need to take them back and have them re-balanced.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 10-01-2013, 02:34 PM   #4
parkermoeder
thanks
-OEM Painted GFX
-Blue oracle halos
Old 10-01-2013, 02:36 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
You need the wheels re-balanced
vroomapunk is offline   Reply With Quote
Old 10-01-2013, 03:04 PM   #6
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
Make sure it's road force balancing as well. Do NOT go to NTB.
Dfault is offline   Reply With Quote
Old 10-01-2013, 04:11 PM   #7
Infinite-T
Infinite-T's Avatar
Drives: 2011 1LT RS RJT
re-balance
Build Thread:http://www.camaro5.com/forums/showthread.php?t=196385
Originally Posted by Synner View Post
If you'd rather drive a civic that eats your soul than a camaro that eats your wallet then thats your choice.
Infinite-T is offline   Reply With Quote
Old 10-01-2013, 04:23 PM   #8
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
parkermoeder you mention "...the car is pulling one way..." as well as the shake. Sometimes if the alignment is good, but a tire is bad, you will feel a pull or drift to one side. If this continues (and if you can switch the tire/rim to the other side) and it now it pulls or drifts to that side, then the tire is probably bad.
Switch the front tires from side to side first, drive the car.
If no change then switch the rears from side to side.
If no change then it is probably a slight alignment issue. As others have said, the alignment will not affect the shaking however.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
