06-21-2012, 01:07 PM | #1 |
Drives: Born Mar09 Join Date: Nov 2009
So how $&%$!* am I? Help, See Pic...
By no means am I a uber gear head. I am however pretty mechanical and do basic maintenance on my vehicles. I have changed the oil in my V6 Lt about ten times and have roughly 30k on it. I was removing the upper oil filter housing and the cast nut broke off. This was not over torqued and I tightened to 20NM on every change. The nut literally broke off in a peculiarly pathetic way. New upper housing ready to pick up from GM parts tonight. I can't find a nice (non AL) stronger aftermarket upper oil filter housing anywhere online. Soooo.....how do I get the old filter cap off without surgery? Award winning photography attached.....
06-21-2012, 01:09 PM | #2 |
Drives: 2010 2SS/RS M6 Black/Black Join Date: Apr 2009
Looks like a casting flaw to me
Pittsburgh Automotive Photography Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake |
06-21-2012, 01:11 PM | #3 |
Raised by Wolves
um are ya still under warranty? If so wouldn't they come get it and flatbed it to the dealership and fix it under the warranty?
If not I think your title said it all, buddy. Good luck with that! |
06-21-2012, 01:11 PM | #4 |
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes Join Date: Jan 2010
Yep. Id have it towed to the dealership and make them fix it
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit. |
06-21-2012, 01:20 PM | #5 |
Drives: 2016 CAMARO 1SS Hyper Blue Met. Join Date: Jul 2009
proud member "club elite" # 89
06-21-2012, 01:48 PM | #6 |
Drives: 2011 SS/RS Join Date: Apr 2010
He can try to get them to fix it, but my guess is they will say he overtightened it and it's his fault.
06-21-2012, 01:50 PM | #7 |
Let's go Rangers!
This!
06-21-2012, 01:54 PM | #8 | |
Drives: White M6 1LT RS Join Date: Mar 2010
That will NOT be covered under warranty. He did it. Now if the dealer was changing the oil and did it then different story.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
06-21-2012, 01:55 PM | #9 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
The strap wrench might work, however there isn't much room in there.....
NOW. since you have the new housing (cap), what you could do, and what I would try, seeing as how the hole is oblong and not round, I wound find something like a combination wrench (the open end) that will fit in the hole, and use another wrench to turn it. oh and btw Mike..... Welcome to our happy little corner of the net, and to Camaro5. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, wive's, husbands and boyfriends here don't care....and take it easy. oh...btw....every once in a while a food fight breaks out...so you may not want to wear nice clothes here. Welcome!!
06-21-2012, 01:56 PM | #10 |
Drives: 2010 2SS/RS "Orange Crush" Join Date: Jul 2010
Wow!!
" When your ready to quit, your 1/2 way there"
" Drive It Like You Stole It "
[SIGPIC][/SIGPIC |
06-21-2012, 01:56 PM | #11 | |
Drives: 2011 Black SS M6 Join Date: Oct 2010
06-21-2012, 01:56 PM | #12 |
Drives: 2012 SS/RS M6 AGM Join Date: Apr 2012
That's a nice one. Real nice. Good luck getting it fixed up! I still think that, no matter how hard it was torqued, the casing wouldn't just rip apart like that. That was alotta force.
Pin it to WIN it!
06-21-2012, 01:58 PM | #13 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
06-21-2012, 02:00 PM | #14 |
Drives: 2010 camaro with fast lane stage 2 Join Date: Apr 2011
its actually kinda easy i see this alot at my dealer i work at take a hammer and a punch and tap it around the bottom till it moves then just replace with new cap and new cap comes with a oil filter i think its like 22 dollars
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back |
Tags |
upper oil filter housing |
