12-14-2017, 09:01 PM | #1 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
How long would you wait before rebuilding/overhauling?
I'm just curious... with over 123k, the car is running fine. No codes, no issues... smooth acceleration with some lifter noise. But this car running 'fine' will obviously not always be so.
I want to avoid catastrophic failure, of course. I will perhaps start to feel something, like rough idles or higher gas consumption? Rather than roll the dice between the first or the later, at what mileage should I consider rebuilding or overhauling the LS3? I always wanted an LS7 too, this is still an option. This more likely if there is catastrophic failure.... meaning something like a cracked engine block or a spun bearing etc. Ya'll keeping these keepers will run across this same question one day I'm sure... |
12-14-2017, 09:29 PM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
How's the compression, cylinder to cylinder? If it's good, I'd say enjoy your good luck and hard work at maintaining it properly. IMO, major failures are often caused by poor maintenance. In 40 years of driving and maintaining my own cars, I've never had a major failure. I am pretty strict on maintenance, but in all honestly, I don't beat on my cars too badly. I hope to get to 123K in mine too without a major issue!
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
12-14-2017, 09:39 PM | #3 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
You kind of sound like your Jonesin’ for an upgrade. Don’t blame you there. I’d say 123K is pretty good justification too. As you say, the day will come. I have 7200 miles on mine. You’re a damn sight closer than me if that puts it in any perspective.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
12-14-2017, 10:00 PM | #4 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
60k for me, I wanted a stroked/forged road racer ;o)
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
12-15-2017, 12:34 AM | #5 |
Drives: 2015 V6 6MT Join Date: Mar 2017
My last car was still running strong at 21 years old and 333K miles. That was a VQ30 Maxima though. If it aint broke don't fix It, unless you want to modify it.
12-15-2017, 04:15 AM | #6 |
i would maintain it well and wait for an obvious problem.
12-15-2017, 07:55 AM | #7 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
If a car is not abused and its properly maintained, I contend that the engine should not need overhauling. I would consider overhauling if the car has done an unusual amount of miles and the engine is showing signs of excessive wear, at I'd say over 300,000 miles.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
12-15-2017, 08:04 AM | #8 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I sense you have an itch to try something new or make some mods?
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
12-15-2017, 10:14 AM | #9 |
im hoping for that much.at what point are timing chains,etc. a problem?
12-15-2017, 10:25 AM | #10 |
Drives: 2018 1SS M6 Join Date: Nov 2014
This is really a hard question to answer as we are getting into rather uncharted territory with the Gen IV engine. Most of these have gone into Corvettes and Camaros, or which most don't really see full time duty. So with a handful just beginning to get to that 6 figure mileage mark, it's hard to say.
A well maintained engine should run for a very long time. Especially with the latest tech in oil and fluids, not to mention overall engineering technology. However, sometimes it is the wear and failure of components, like plugs, ignition systems, balancers, driveline parts that can cause stress on internal engine parts as well. A slightly off balance hub can cause stress on rod bearings for example. Or a under performing plug or coil pack can cause incomplete fuel burn which eventually will cause wear on the cylinder and rings, etc. A lot can happen, it's more than just changing oil. |
12-15-2017, 11:45 AM | #11 |
Great responses, thanks. I do take good care of this car. I wish it would last forever but we all know this is wishful thinking.
If it ain't broke, don't fix it - seems like a good philosophy to have on this. Continue to take care of it and hope for the best. |
12-15-2017, 11:59 AM | #12 |
Drives: 2013 LS3 Camaro Join Date: Jul 2017
There was a guy on here who had his Camaro up to 200,000 miles. He didn't have any issues with the engine if I recall correctly. I think he had a couple of minor minor issues.
12-15-2017, 12:56 PM | #13 |
Well built timing chains and a well maintained engine should go the entire distance. But a rule of thumb is to evaluate your valve gear/moving parts at 100,000 miles or at that interval. As someone here put it so well, if it aint broke don't fix it.
12-15-2017, 12:57 PM | #14 |
It will last as long as you are willing to fix/drive it. Usually rust/corrosion and accidents are car killers.
