12-26-2016, 01:18 PM | #1 |
Drives: 2011 Camaro SS Supercharged Join Date: Sep 2012
Which Shifter?
Ok, so I want to replace my factory Hurst shifter with either a MGW, Hurst or Barton and am curious to what everyone thinks is the best. I have a friend with a Barton but don't know anyone with a Hurst or MGW. Opinions?
12-26-2016, 01:19 PM | #2 |
Forgot to add, my Camaro is a SS with a Whipple Supercharger, COM CAM, methanol injection for 785 HP at the flywheel. Thanks.
12-26-2016, 06:13 PM | #3 |
Drives: 2012 SS Camaro LS3 Join Date: Jun 2012
MGW all the way...Built like a tank and have not missed a shift....you will love it
2012 Ashen Grey LS3_ARH 1 7/8 Long tubes_Pypes Exhaust Axle Back_C.A.I._ Bo White Ported Throttle Body_Custom Black Anodized Fuel Rails_3:91 Rear ARP Stainless Bolts_MSD Wires_Elite Engineering Catch Can_MGW Flat Stick_Stewart Warner Pro Gauges_BMR Rear Suspension_ZL1 Rear Swaybar 427 HP To The Wheels_Tuned and Dyno'd by ECS |
12-26-2016, 07:52 PM | #4 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
Another vote for MGW. I had a hurst for 2 years and switched to mgw. Should have just went with mgw to start with. Hurst rattles and is rougher. Mgw also feels much tighter with no slop.
12-27-2016, 01:51 PM | #5 |
Drives: 2011 Green SS M6 Join Date: Jun 2015
HURST---5 1/2 years and No Problemo
12-27-2016, 04:39 PM | #6 |
Drives: 2015 Camaro 2SS LS3 Join Date: May 2013
I have no experience with the Barton or Hurst, but I do LOVE my MGW!
12-27-2016, 04:52 PM | #7 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Had the factory short-throw Hurst. Researched. Went with MGW. Installation was straight forward. Tighter shift gates. Like it. Also, was able to attach the old school T-handle Hurst shift "knob." Recommended.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
12-27-2016, 09:13 PM | #8 |
Well boys, I like what I'm hearing and it looks like the MGW is the shifter of choice. The install video and the test ride they show really seals the deal. Thanks for all that replied.
12-31-2016, 08:54 PM | #9 |
Drive Fast Take Chances
I got the MGW and had Don install it,looked like a pain without a lift
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/ |
01-01-2017, 11:35 AM | #10 | |
How do you like the MGW? I've nothing but good things about it. |
01-01-2017, 03:04 PM | #11 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
MGW is a nice piece. Installed that and their Race Knob to replace the OEM regular stock shifter and it was an improvement. That said, I later pulled the MGW out to install a pre-owned GM Hurst. The GM Hurst is quieter than MGW and still works great.
In my case, the MGW solved a problem I just did not have. Sold the MGW for close to what I had in it. The MGW Race Knob is absolutely necessary in my opinion and it fits perfectly on the factory GM Hurst shifter. Best setup for me. Your results may vary. |
01-03-2017, 10:02 AM | #12 |
Do somethin fun every day
01-03-2017, 10:21 AM | #13 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
MGW man, you won't regret it
01-03-2017, 01:10 PM | #14 |
Drives: 2013 ZL1 Join Date: Nov 2012
MGW
