06-27-2017, 08:08 AM | #29 | |
Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
If I am not mistaken, you'd add the sensor, load a "flex" tune in, and let the vehicle compensate accordingly?
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built! |
06-27-2017, 09:26 AM | #30 |
Drives: 17 ZL1 Join Date: Mar 2017
The same. The tuner fills in the tables for all the different ethanol percentages and the sensor allows the ECU to make adjustments, so whether you want to run straight E85, a blend or 93 only it will do it no problem. I drive my cars long distances and if it could have only been a E85 only tune I would not be doing it.
06-27-2017, 09:29 AM | #31 |
Hmmm...
So the sensor allows for multiple fueling tables to be accessed at any given time? I don't really drive long distances at all, and have E85 accessible pretty much any time, so on my Mustang I always ran the corn. Would have to reflash for a 93 tank. Is this done through an HP tuner package?
Built! |
06-27-2017, 10:55 AM | #32 | |
06-27-2017, 11:00 AM | #33 |
Thank you for the info! Definitely something to think about...
Built! |
06-27-2017, 11:15 AM | #34 | |
I ordered this one (delivered today) and should be going on this weekend. I'll report back with results. |
06-27-2017, 11:41 AM | #35 |
Drives: Red Hot track candy Join Date: Oct 2009
Mike. You feel okay on track with it? Is there higher than 10% chance a tuner can create volatility here?
Standing by on this. Eager for your report.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
06-27-2017, 11:50 AM | #36 | |
Doubt I will notice the extra 40 or so HP but should see a little improvement in track times and maybe some cooler temps. |
06-27-2017, 12:04 PM | #37 |
Drives: 2017 ZL1 A10, 2015 C7 Z51 Join Date: Aug 2011
The Flex Fuel sensor is in-line with the tank pump near where it enters the high-pressure pump. It will monitor the ethanol percentage continually. The tables are then setup to adjust from 0-80% ethanol I believe with anything over 80% having no impact (no added timing or fuel). The tables sit on top of the base 93 tune. So if you have 5% ethanol in the fuel, it basically adds no extra timing or fuel to compensate, but from there it adds and adjusts the fueling and timing if additional ethanol is registered. Think of it as a volume knob on an amplifier except instead of getting louder, it makes more power.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
06-27-2017, 12:11 PM | #38 | |
None of my tracks have E85 at the pumps so this is good to understand (for days I am not hauling the trailer to the track with extra fuel).
06-29-2017, 08:09 PM | #39 |
Drives: 2017 NGM ZL1 Join Date: May 2015
Mine was delivered today, let me know how the install goes, I don't know if I'll have time to tackle mine this weekend so any little tips you have would be great; like where you are gonna route the pin to the ECU. Gotta keep it clean lookin!
06-29-2017, 11:57 PM | #40 |
"BEASTM*DE"
This is great for 6th Gen owners only needing the Flex Fuel Sensor...For the 5th Gen the cost could be as high as 3k for a proper system installed...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
07-05-2017, 06:52 AM | #41 |
Got my sensor on over the weekend. Went in like a breeze, I wish their cable that ran to the ECU was a bit longer so I could have hidden it a little more but it is by no means too short.
07-05-2017, 07:46 AM | #42 | |
Drives: 2019 Corvette ZR1 Join Date: May 2017
I guess I haven't watched Camaro6... haha. I'll have my low side pump kit available soon as well for you guys. I've been working with HPT to get some functionality added to the ECM that'll make the kit work better as well. Stay tuned. |
