Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 12-26-2013, 12:21 PM   #1
loliveira08
Drives: 2013 Camaro 2LT/RS
Exhaust Question!
So I just got my MRT 2.0 and Xpipe installed and let me just say it sounds AMAZING.
The videos online do not do it any justice!
I just had a question, is it normal to feel a bit of rumble in the seats when at a stop? I've never had an aftermarket exhaust and was just wondering.
Not sure if it matters but I had the resonators removed and new pipes from the x-pipe and back.
loliveira08 is offline   Reply With Quote
Old 12-27-2013, 02:37 PM   #2
skibik
Guest
Drives: bbbbbb
Glad you love the sound and welcome to the V2 club. You don't have anything loose that could be vibrating that would make you feel it in the seat? I don't have the x-pipe myself but maybe there is enough of the sound transferring or resonating into the car at idle. I don't feel it in mine. I have the Solo HFC's on mine and since I have an auto the trans brace is in a different spot and my drivers side pipe was touching the trans cross brace and it would vibrate and resonate into the car at idle. You may want to get under the car and check to make sure everything is tight and not touching anything. Make sure exhaust is cold before grabbing anything.
Dean.
skibik is offline   Reply With Quote
Old 12-28-2013, 03:17 PM   #3
rickyrocket
rickyrocket's Avatar
Drives: 2015 blk 1 SS
Does sound xcellent tho !!
15 1 SS
rickyrocket is offline   Reply With Quote
Old 12-29-2013, 07:12 AM   #4
loliveira08
I had them remove the brace because it was rattling wat too much at a stop. I still get the vibrating some times but it's nothing that bothers me too much! I might swing by sometime this wee just to have the guy take a quick look at it!
Old 12-29-2013, 11:24 AM   #5
skibik
Guest
Drives: bbbbbb
You had them remove which brace? I sure hope it wasn't the transmission brace?
Old 12-29-2013, 11:29 AM   #6
Awill
Married
Awill's Avatar
Drives: 2011 Camaro 1LT/RS
hope you get it taken care of if needed and nothing thats an issue. post video.
Awill is offline   Reply With Quote
Old 12-30-2013, 10:58 AM   #7
loliveira08
Don't think it was anywhere near the transmission! Think it was just holding the exhaust piping.
Old 01-01-2014, 01:09 AM   #8
kk0239
kk0239's Avatar
Drives: 2013 2LT Camaro
you have any drone?
kk0239 is offline   Reply With Quote
Old 01-01-2014, 07:21 PM   #9
loliveira08
Honestly couldn't tell you man! I have no idea what drone sounds like.
If I'm on the highway and let go of the throttle, I hear nothing from the exhaust!
Old 01-01-2014, 07:49 PM   #10
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
That's the driveshaft tunnel brace, it stiffens the driveshaft tunnel area under the carrier bearing for the two piece drive shaft. It probably won't hurt anything to remove it because the factory one is thin and flexes quite a bit anyway... However, you should be able to loosen most of the clamps in your exhaust system and push the pipes up (rotate) them so that they don't hit... Unless you have 3" exhaust in some cases, it will still hit... You could also buy an aftermarket tunnel brace which will usually clear 3" exhaust, or exhaust that touches the factory brace, or many people also use washers in between the brace and the under body of the car to space it down if their exhaust touches.
Old 01-01-2014, 08:11 PM   #11
dmginc
dmginc's Avatar
Drives: In Circles
this.
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 01-02-2014, 10:31 AM   #12
loliveira08
Awesome you guys! Thanks for the tip! As soon as the snow is off the ground here I'll get under there and place some washers!
Old 01-02-2014, 11:38 AM   #13
19car69
19car69's Avatar
Drives: 2012 1LS
Snow is off the ground? You can't let that stop you from getting under your Camaro.
2012 1LS, Cold Air Inductions CAI, Apex scoop, Apex water bottle relocation, VMax Ported TB, Vitesse Throttle Controller, BMR Sway bars, BMR 1.2" drop springs, Koni rear shocks, Elite catch can, Solo Performance V6 Mach X-LFX Cat-Back Exhaust, Hex Vents, 1LE strut tower brace, Barton short throw, separate clutch reservoir, American Racing TORQ THRUST M 18X9, HiTS radio with reverse camera, GM Blade Dovetail spoiler, 2010 leather wrap steering wheel, vented engine cover, added Homelink to overhead console.
19car69 is offline   Reply With Quote
