03-20-2017, 06:30 AM | #1 |
Drives: MBM 2016 2LT RS Join Date: Dec 2015
psi/kpa accuracy?
How accurate is the reading on the display (or mychev app) in regards to the tire pressure? I just added air to all tires because the display looked as though I would have only ~30 psi, ~200kpa however while adding I had to get the air to about 40 before it read as 35-36 on the app.
I'll probably pick up a guage to test it, but just wondering if anyone knew if the car guage / app needs to be calibrated first? |
03-20-2017, 07:44 AM | #2 |
Drives: 08 Accord V6/M6 / 04 Canyon Z71 Join Date: Aug 2008
How did you get the air to 40 psi if you don't have a gauge? If it was one of those gas station pumps with built in gauges, those are usually inaccurate.
03-20-2017, 08:00 AM | #3 |
That's what I meant... I was using the gauge on the gas station pump. So sounds like I can trust the accuracy of the display? That display doesn't have anything to do with TPMS which could have been not calibrated? (sorry , I know nothing about the TPMS system and how it works)
03-20-2017, 08:01 AM | #4 |
Drives: 2016 Summit White 2SS (Auto) Loaded Join Date: Jul 2016
Just buy a digital gauge and use the kpa to set
03-20-2017, 11:22 AM | #5 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
I replace one of my GM vehicles almost every year and I have found the readings for tires to be either spot on or within a degree. The readout on the app is from your last drive so would be hot tire temp, no cold that you want.
03-20-2017, 12:47 PM | #6 |
The tire pressure monitors within each wheel are supposed to be accurate within 1 psi. I find them to deviate as much as 2 psi from my old school pencil style gauge. The digital gauges on amazon are accurate within 0.5 psi out of the box. Sounds good enough to me.
03-20-2017, 05:31 PM | #7 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Good enough for DD use.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
