Old 04-21-2020, 06:14 AM   #1
Gary Frank
Drives: 07 Vette 19 Camaro92 350 S10
Smile Boost Gauge
Recently got my 19 ss2 back from install of LT4 blower. Car has headers exhaust. M6. Question- what value is boost guage to me. Car currently running stock pully. set at 7lbs boost. 93 oct gas. No interest in going further for now. opinios?
Gary Frank is offline   Reply With Quote
Old 04-21-2020, 08:56 AM   #2
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
you don't really need one presa, however you want to see how much boost your pushing, that's the only real benefit.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 04-21-2020, 02:11 PM   #3
Tim M
Drives: 2018 Camaro SS 1LE
I just did the same swap...other than checking to see what boost the pulley's produce - little else.
I did add one to mine temporarily to confirm what I was seeing in HPTuners...initial readings return over 11 psi! Mine is stock LT4 pulleys as well...as well as everything else.
Interesting you have a much lower number...
Tim M is offline   Reply With Quote
Old 04-21-2020, 05:13 PM   #4
parbreak
Drives: 2017 50th Camaro SS
Mine spiked up to 11 psi on a Procharger P1X. But, we found the cats were clogged. Cut those out and now it's back down to where it should be 7-8 psi.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 04-22-2020, 02:36 PM   #5
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Isn't the stock LT4 setup on a LT1 different boost numbers because of the different Compression ratios?
Where the LT4 runs 7 psi and the LT1 runs much higher?
cheeze9878 is offline   Reply With Quote
Old 04-24-2020, 01:26 PM   #6
Tim M
cheeze9878: I believe the difference is combination of larger cam and higher compression of the LT1.
But I assumed the OP had an LT1 (install of LT4 blower) - I may assumed incorrectly though. He also has headers which will drop the boost number.
Old 04-24-2020, 02:38 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
you can use the Torque pro app on a tablet or phone with a bluetooth obd2 device and scan most engine parameters including boost.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-24-2020, 06:23 PM   #8
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Good info.
Would this boost reading/data be the same as on the cluster boost gauge in the ZL1?
Wish it could be somehow enabled in the cluster of the SS as well (I.E instead of the Battery or Oil pressure gauges locations?).
I understand that this requires a proper GM OE Firmware (file) adjustment in the ECM.
None of the tuning suites made this possible so far (I.E. EFI-L nor HPT)
Old 04-24-2020, 09:20 PM   #9
KingLT1
KingLT1's Avatar
No I don't think so but I agree it would be nice.
Here is a screen shot of the layout on my Torque App for reference.
2016 NFG 1SS A8
Old 04-25-2020, 04:35 AM   #10
Eldi Z
Looks good
Old 04-25-2020, 11:16 PM   #11
2016SDSS
Drives: Chevrolet Camaro
Tim M
I did the lt4 swap as well with stock pulleys. Seeing 11 psi on stock manifolds
2016SDSS is offline   Reply With Quote
Old 04-26-2020, 08:17 AM   #12
L78toLT1
L78toLT1's Avatar
Looks good, King. Any custom pids needed, other than e%?
I still have not been able to get my pid for e working on my galaxy s10e.
Baby Blue
Old 04-27-2020, 06:31 AM   #13
Gary Frank
Thanks for all the responses. Much appreciated
Old 04-27-2020, 09:34 AM   #14
KingLT1
KingLT1's Avatar
nope. E content is the only one that requires a custom pid.
2016 NFG 1SS A8
