TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 07-01-2012, 12:05 PM   #1
ndtguy
^ Me. Things I write ~>
ndtguy's Avatar
Drives: 2010 Camaro SS
Send a message via AIM to ndtguy
Suspension: Myth vs Fact
Very good write up. Just thought I'd share.
http://hewsoninc.ca/mythinformation.htm#lca_brackets
ndtguy
New DD: 2010 Camaro SS L99/A6 - bone stock.
Gone but not forgotten...
- 2001 Camaro SS m6 - SLP lid, free ram-air mod, poly sway bar bushings/end links, BMR springs and bilsteins.
- 1998 Trans Am m6, forged 347, T70;alky-water injection; intercooled, 208/230 .549/.579 121LSA, Moser 12 bolt, 561rwhp/611rwtq.
ndtguy is offline   Reply With Quote
Old 07-02-2012, 09:47 AM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
One must keep in mind (and be completely honest with themselves) the type of driving they do and what they want from their vehicle.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 07-03-2012, 01:20 AM   #3
ndtguy
ndtguy's Avatar
True. If straight line is your thing, poly it.
If taking turns is your thing, I would stay away from Poly on the axle side (rubber or rod/rotor joint).
Snap oversteer is a scary thing.
ndtguy
Old 07-03-2012, 05:21 AM   #4
pv-camaro
pv-camaro's Avatar
Drives: Camaro 2001 3.8V6
The bushings for the lower control arms could be changed with the 1LE ones (same ones sold by Moog).
For the panhard this is a different story, the only performance options are the ones with polybushing en Rod/rotor ends.
The panhard from the SS Camaro/Firebird is not available anymore, so there is nothing more to choose
pv-camaro is offline   Reply With Quote
Old 07-03-2012, 09:07 AM   #5
ndtguy
ndtguy's Avatar
I plan on running 1LE bushings in my LCAs. I looked for a 1LE PHB and couldn't find one so like you, its off to the aftermarket for mine.
ndtguy
Old 07-03-2012, 09:26 AM   #6
demonspeed
demonspeed's Avatar
Drives: Camaros
Not that I believe it's not possible, but I have a hard time believing that snap-oversteer is actually a concern, even with the poly bushings, with the three link setup 3rd/4th gens have. If anyone has spent time in a fox body, they will know how easy snap-oversteer occurs. However, it's not something that easily occurs in the Camaro - even with the bushings (in my experience, anyway).
10/13/22: 1100
Old 07-03-2012, 11:21 AM   #7
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
I'm running poly bushings, with my LCA's on the lowest setting. I run the car hard and Auto-X it regularly. I have no issues with getting loose in the corners.
That said I don't like the poly bushings and will be swapping to Adjustable LCA's with roto joints in the future. The poly does bind, make a lot of noise, and is rougher than needed. I was just a noob when I bought them 3 years ago and was lead to believe they were the best at the time...
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 07-03-2012, 02:57 PM   #8
ndtguy
ndtguy's Avatar
I know Fox body oversteer all to well.
I didn't have snap-oversteer with the TA, but I don't recall pushing it anywhere near as hard as I do with this SS (unless of course you count the turbo spooling up hard in the middle of the apex, that increases the pucker factor quickly).
I got the link off of LS1tech in a thread where the guy was having a lot of issues with snap-oversteer. I re-read the article and he added a 3rd gen (22mm?) rear bar on his car without upgrading the front bar (30mm) on his 4th gen. He also had poly bushings everywhere in his setup, so who knows? He was told to put the 19mm bar back on. If he still had issues, the next step was to get rid of the poly.
ndtguy
