Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 07-29-2011, 09:28 PM   #1
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
Going to 16" to 17" wheel question
In about 4 weeks or so im planning on getting some 17" rims for my camaro,after I get these wheels on it, am i going to have to get the speedo recalculated for the correct speed. and if so, how? Thanks
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 07-29-2011, 09:34 PM   #2
I think you might have more things to deal with than speedo. Depends on the tire size you put on them...
Old 07-29-2011, 09:41 PM   #3
insidethreat07
Id have to see abput the tires but what all would i have to do? hopefully its not a pain in the butt :/
2001 Camaro V6
2016 Camaro 2SS
Old 07-29-2011, 10:09 PM   #4
Whoops never mind... I got lost and ended up in the 4th Gen threads...
Just keep the same tire height as stock and you should be good to go w/ the speedo. I'm sure there some experts out there who can help you much better than I.
Old 07-29-2011, 10:09 PM   #5
Supercharged SS
Drives: 2010 Camaro
You can get 17's with a tire the same height as the stock tires. Problem solved.
Supercharged SS is offline   Reply With Quote
Old 07-29-2011, 10:18 PM   #6
insidethreat07
thanks for the info, i was wondering aobut the tire height
Whoops never mind... I got lost and ended up in the 4th Gen threads....
lol well i hope you got good directions back to where you was going :P
2001 Camaro V6
2016 Camaro 2SS
Old 07-30-2011, 12:25 AM   #7
pv-camaro
pv-camaro's Avatar
Drives: Camaro 2001 3.8V6
When i bought my 2001 3.8V6 Camaro, he has the orginal tires on it 215/60/R16, with 16x8"snowflake rims.
I replaced the tires with the Z28 size 245/50/ZR16, this tire is al little bit less heigh.
I solved this problem by buying a Hypertech 32002, and corrected it
It is also handy, you can remove the speed limiter, read problems (and reset), change shifting point (automatic).
pv-camaro is offline   Reply With Quote
Old 07-30-2011, 02:34 AM   #8
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Nope, speedo will take care of itself. A tune couldn't hurt when upping your wheel size, and (depending on how big you're going) some bigger brakes. But you're only going up 1", I think you'll be fine just bolting them bastards on and driving away.
"Tops off, tach up baby- loud and proud!"
A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp
Revo1 is offline   Reply With Quote
Old 07-30-2011, 09:03 AM   #9
pv-camaro
pv-camaro's Avatar
What do you mean by "speedo will take care of itself", the ECM can not think by itself
i replaced my 215/60/R16 (outside diameter 26,2") with the Z28 size 245/50/ZR16 (outside diameter 25,6").
and the odometer was not correct anymore, i checked it also with a navigation system TOMTOM)
With a Hypertech 32002, you can give your outside diameter of the tires, and aif you changed your axle , you can correct this too
Old 07-30-2011, 09:25 AM   #10
insidethreat07
ill prob just bolt them on and check the speed with my gps and go from there, if its only like 1 or 2 mph i might not even worry about it lol
2001 Camaro V6
2016 Camaro 2SS
Old 07-30-2011, 11:41 AM   #11
Revo1
Drives: 2010 2SS/RS
I stand corrected. Obviously it will not adjust itself, but seems odd that it should need adjustment at all. Hell, at this rate maybe I'll swap out for some 28"s, and just drive 145 everywhere I go
Old 07-30-2011, 12:10 PM   #12
insidethreat07
if i would take it to my dealer in town could they do all that for me too?
2001 Camaro V6
2016 Camaro 2SS
Old 07-30-2011, 12:11 PM   #13
That sounds like a good plan...
Old 07-30-2011, 10:56 PM   #14
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
You should be able to get a tire size close to the stock 26" height. Just depends on what kind of wheel you are trying to run.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Steering Wheel Controls and PDIM Add-On HUGE question havoksin Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 02-23-2011 10:53 PM
NEED YOUR HELP!: Wheel Offset Question vdevine Wheels and Tires Talk Sponsored by The Tire Rack 4 02-16-2011 09:07 PM
Question: Cars only driven by one wheel? JMROD General Automotive + Other Cars Discussion 17 08-29-2010 04:04 PM
question about wheel locks j0hnny007 Wheels and Tires Talk Sponsored by The Tire Rack 3 03-17-2010 09:05 PM
Question about steering wheel and shift knob jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 08-27-2009 03:45 PM
