Old 05-06-2017, 06:56 PM   #1
Paulbates455
Drives: a car
Paulbates455 is offline   Reply With Quote
Old 05-06-2017, 10:58 PM   #2
Slickcas
Drives: 12' 2SS/RS LS3 IBM
May have just picked up a turd. Sad but ALL car makes have them. Back in the day the GM 2.8 only had 120HP but some would put down 120+ to the wheels others about 75!
Never seen a A8 not walk all over and away from a stock 5.0
Slickcas is offline   Reply With Quote
Old 05-06-2017, 11:03 PM   #3
ex-SS-ve
ex-SS-ve's Avatar
From a roll or standstill? Not a single issue here making those kills.
ex-SS-ve is offline   Reply With Quote
Old 05-07-2017, 02:17 AM   #4
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Do you have a dyno anywhere near you? See if they've tested other 6th gens and run your's to see if you are putting down comparable power.
That or take it into the dealership.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 05-07-2017, 09:11 AM   #5
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
So you drive over 5 hrs from Houston, to the nearest point of entry to Mexico, to get whipped by dodges and 5.0's??
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 05-07-2017, 09:54 AM   #6
Zack46
Zack46's Avatar
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 05-07-2017, 11:32 AM   #7
Chadicus
Drives: 2017 2SS M6
Originally Posted by Paulbates455 View Post
I lose to other 6th gens by a car length or so. Stock vs stock. Srt dodges same results. And can't pull away from 5.0s. It's an auto so I keep in sport and and just mash the gas. All in Mexico of course. First auto performance car I've had. I did good with my manual 5.0s. Did I get a turtle or am I going about this wrong? Be honest. Not gonna get butt hurt. Any input would be great.
Couple questions first: How many miles are on your car? Are you using competition mode? Most importantly how do you know these 5.0s are stock? Mustangs have a HUGE aftermarket. By the way the SRT 392 and Scat Packs are pretty fast in their own right.
Chadicus is offline   Reply With Quote
Old 05-07-2017, 11:40 AM   #8
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
Also fill up with good 93 and make sure the car isn't pulling timing. Take it to a dyno.
JacobC1983 is offline   Reply With Quote
Old 05-07-2017, 12:26 PM   #9
F1FTY
Drives: 2018 ZL1
Pull IM and TB and check for oil?
F1FTY is offline   Reply With Quote
Old 05-07-2017, 01:26 PM   #10
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
I have been out-trapping and beating the 5.0's and SRT8's handily at the track when I was stock. Are you going from about a 40 roll or 50? These autos have a bit of a lag when you don't roll from a good shifting point. Easy to lose to cars that are quite powerful like the 5.0's and SRT8's.
Old 05-07-2017, 01:27 PM   #11
Chadicus
Drives: 2017 2SS M6
The car has almost 8000 miles on it and I don't have it in competition mode.
Sorry, I'm new to navigating forums.
Ok so after 8k miles your car is broken in. Like the poster below my original post make sure you are using premium fuel. Also use track/competition mode. Never assume any 5.0 is stock either anyone who has one and wants to race gen 6 camaro probably has a tune at the least.
Old 05-07-2017, 01:41 PM   #12
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Try to answer your questions in the order I remember.
From a roll. Don't know if the 5.0s are modded, except for exhaust on one for sure.
I've never been to Mexico.
The dyno was a great idea. Tons of speed shops here.
I did not understand the capitalized initials of where to check for oil.
Thanks for the input.
I didn't get the yellow smiley faces either.
I guess that and the question before was some kind of burn.
If roll racing you need to learn to use the paddles. Downshift manually to the best gear for the speed you are at (put shifter in the manual gate). As soon as you nail the throttle, throw the shifter back into Drive so it will do its thing. Like jdasnt3 said, the auto can take a critical second or two to downshift in Drive. Better yet, tell those babies to do run it from a dig or they are just proving they can't drive
Old 05-07-2017, 01:45 PM   #13
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Do this:
Old 05-07-2017, 07:11 PM   #14
WhyUMad1LE
Drives: 17 SS 1LE
lol
