10-02-2016, 08:07 PM | #1 |
Drives: 15' Camaro ZL1 Supercharged M6 Join Date: Aug 2016
ZL1 5GEN ... Power Shuts Down.... NO Warning???
Anyone have this happen with thier ZL1. Mine is a 2015 with only 7400 miles. The stability control light starts flashing and car loses power and shuts down. Wait a few minutes then starts back up request you roll down and up both windows. Did it 4x yesterday 10/01/16 trying to get back home. First time after starting back up check engine light came on but didn't come back on after turning off normal and starting back up normal. Really no warning so glad I wasn't trying to make a turn across oncoming traffic..... maybe a ECM, Stability Tract component, or Throttle body failure?
10-02-2016, 08:32 PM | #2 |
Get Some
Drives: 2014 ZL1 6Speed Join Date: Mar 2012
any mods?
10-02-2016, 08:42 PM | #3 |
Just a CAI Cold Air Intake system back in August 2016.
10-02-2016, 09:56 PM | #4 |
Sarcasm loading --------
how is battery voltage?
could possibly be a bad ECM otherwise.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
10-02-2016, 10:02 PM | #5 |
voltage slightly over 12 once restarted and running "normal". I was wondering if it was the ECM too. Thanks for the feedback. Dealer can't get me in until Thursday at this point. Going to try to limp it up to Advanced Automotive to get a code reading but the check engine light isn't on anymore. I assume codes will have already been captured.
10-02-2016, 10:03 PM | #6 |
Drives: 2015 ZL1 Join Date: May 2015
bad ground??
10-02-2016, 10:50 PM | #7 |
I hope to know more after I get the codes pulled tomorrow. I'll post them when I get them. Thanks.
10-03-2016, 12:47 AM | #8 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Most likely ECM. I had the same issues and they replaced it. Many others have had similar experience. A CAI could give you a check engine light if it requires a tune. But if it is a no tune not likely unless you combine it with headers and maybe a throttle body. Then it wants a tune.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
10-03-2016, 09:35 AM | #9 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Simple issue....bad ground from changing your CAI.
Bigger issue....bad ECU which the dealer will have to fix. good luck.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-03-2016, 08:39 PM | #10 |
Well took it up to Auto Zone for the codes to be read and surprisingly no codes showed up. My service manager at the dealer said that it may be a bad battery cell due to shutting down and then the window's request reprograming each time. Auto Zone did a battery check and I think it was a circuit check but again everything came back good. I started to leave to drive straight to the dealer and what do you know the car just cut off but radio and mylink display stayed powered up. I had the wife run in and have the guy bring code reader back out without doing anything before plugging it in. Still no codes showed. Car would not turn over at all. We decided to check the fuses and found a blown fuse #22 a 20 amp fuse that dealt with the brakes. We replaced it started up. Took to dealership without shutting off in hopes they can find something or at least reflash the ECM to update it. Stumped.....
10-03-2016, 08:50 PM | #11 |
I changed the OEM AI out back the first week in August 2016 about two weeks after I bought it. Would it show up this late after install. We got the Cold Air Inductions CAI that was very simple to install. Said it didn't need a tune but I do want to have one done. I bought a SCT X4 7416 model but when I went to install it said it was not supported on my 2015 ZL1. I thought I had researched it pretty well and the amazon compatibility system said it was good. After it said it wasn't supporting my car I did a search again and eBay's system said it was not compatible so go figure. Luckily they had me send it back so just waiting on a refund. Once I get this issue straight I plan to take it to the Maryland International Raceway and have them do a dyno pull and tune it. Hopefully that will work any bugs out.
10-04-2016, 08:43 AM | #12 |
KaBoom1701
Sounds like a bad ground to me.
Double check your CAI install.
Mods:
10-04-2016, 08:50 AM | #13 | |
Ted.
www.jannettyracing.com
10-04-2016, 10:04 AM | #14 |
check the firewall connection on the driver's side also. It is a big black plug that may be loose.
Tags |
ecm, power, stability control, throttle body, zl1 |
