dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-31-2016, 08:45 AM   #1
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
Boost gauge install help
I am installing a boost, fuel pressure, and A/F gauge in my ZL1. Everything is wired up and working except the boost. I was hoping to use the "T" fitting and tap into an existing vacuum line. Does anyone know the best place to install? I've been searching for awhile, but everything is related to aftermarket superchargers. Pics would be awesome!
Thanks!
SSmokinSS is offline   Reply With Quote
Old 05-31-2016, 11:40 AM   #2
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
I've also been asking the forum what boost line source to "T" into for my Hobbs switch but no replies back so far.
Im pretty sure it is the pvc plastic tube runs along the passenger side of the blower and goes down into the same area as the fuel rail feed line, but not 100% sure
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 05-31-2016, 12:45 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Last time I spoke to JMS when installing my fuel pump booster I remember them saying the best place to tap into the booster vacuum hose up front labeled "A" I think.....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 05-31-2016, 08:19 PM   #4
131LE
Drives: 2013 ZL1
Im sorry i do not have any pics but you can "Tee" off the line coming off the front of the supercharger going to the bypass valve. I think its labled with an "X"
2013 ZL1
131LE is offline   Reply With Quote
Old 05-31-2016, 11:00 PM   #5
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
I didn't think you had to tap into a vacuum hose for the JMS unit..? I thought it was electronically driven from the gas pedal?
jayno20 is offline   Reply With Quote
Old 05-31-2016, 11:58 PM   #6
ZL1Kid_AL
ZL1Kid_AL's Avatar
These are the only 2 lines I see possible to "T" into. The one labeled X is too small to T into..
Attachment 799096
Old 06-01-2016, 12:00 AM   #7
ZL1Kid_AL
ZL1Kid_AL's Avatar
Old 06-01-2016, 12:02 AM   #8
ZL1Kid_AL
ZL1Kid_AL's Avatar
Old 06-06-2016, 12:17 AM   #9
SSmokinSS
Get Some
SSmokinSS's Avatar
Thanks for the help! Hose with the X on it did the trick! Used the supplied T with a small piece of hose to connect right at the nipple.
