TireRack
Old 01-14-2014, 11:23 PM   #1
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Don't think you need a 3-bolt cam?
Don't think you need a 3-bolt cam? Think again...the following damage occurred at idle while the car was warming up. I will be honest and say that the lifters did grind the cam lobes hard due to improper oil...shouldn't have been running Mobil 1. I know that now.
Pictures are self-explanatory.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 01-14-2014, 11:41 PM   #2
mikeyg36
Drives: 2015 Z/28 #533
mikeyg36 is offline   Reply With Quote
Old 01-15-2014, 12:44 AM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
What oil do most recommend? My turner replaced oil with Mobile 1 syn when cam install was done. They also run the same oil on 700+ hp builds. Hmmm ....?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 01-15-2014, 03:34 AM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The mobile 1 is fine, but there may have been debris on the cam from install, or the cam core was not the 8620 hardened version. We use Mobil on a lot of our builds, but we prelube the cam with non synthetic for install.
Rhino79 is offline   Reply With Quote
Old 01-15-2014, 08:08 AM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
yeah...and let's say you did have a 3bolt...somthing caused the resistance that sheered the pin and bolt. That would have still been there and still damaged valve train and what not.
Sorry to hear about that man.
-John S.
grocerygetter is offline   Reply With Quote
Old 01-15-2014, 08:19 AM   #6
DesertCamaro
DesertCamaro's Avatar
Drives: Fast
Oh boy, that's heartbreaking. I just pulled the AMC 401 out of my buddy's CJ over the weekend. PO swapped in pistons that were too tall, and 5 of the 8 hit the head and were all cracked.
Never a good feeling to open a motor and see that.
2014 SS
DesertCamaro is offline   Reply With Quote
Old 01-15-2014, 08:23 AM   #7
SNSSTR
SNSSTR's Avatar
Not necessarily, pin may have sheared on its own accord possibly from racing it or cold temps, who knows. But I do understand what you're getting at with that statement and it's kinda like "what do you want to be the weakest link" it will always be something...just a matter of what it is I guess.
Old 01-15-2014, 08:24 AM   #8
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Yep, the pin is only there for indexing purposes only. The big bolt and high torque value is what keeps the sprocket stationary. Early on some single bolts failed because the pin was too long and wasn't allowing the bolt a true torque.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 01-15-2014, 08:29 AM   #9
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
Subscribing because I want a cam in my future. Curious to find out what went wrong
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 01-15-2014, 08:31 AM   #10
grocerygetter
instigator
I heard that as well. But those were old cam cores and that was a while back in one bolt design. Also read about the non-hardened cams having isues with that and wear overall.
So that brings up a good question...what are we looking at? Which motor, which cam, mileage?
-John S.
Old 01-15-2014, 09:11 AM   #11
SNSSTR
SNSSTR's Avatar
Well, it's an LS3, cam was put in at 12,000 miles and car now has 20,000 miles. Cam is 6 months old. Comp Cam specs are 219/235 .607/.619 113LSA. Not sure what material it was made out of.
The guy tearing it apart also said there was some valve float. Apparently the Lunati springs didn't hold. Also had trunion upgrade installed at the time of cam install.
Old 01-15-2014, 10:53 AM   #12
Kelly@PCMofNC
Drives: 2010 RS/SS
Man that sucks! Those valves look like they're just swaying in the wind!
Kelly@PCMofNC is offline   Reply With Quote
Old 01-15-2014, 11:10 AM   #13
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
ADM just did my build and my cam was trashed as well, you could see the wear on the lobes and that cam had about 4 thousand miles on it. I think the metal was soft, it was a comp cam. ADM told me to run Mobil 1 15w50 in mine, it has a lot of zinc in it.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
Old 01-15-2014, 11:22 AM   #14
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Motor oil would have nothing to do with this accident I used 10w30
Tommy Boy
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
