Old 02-14-2024, 10:59 AM   #1
nosrettap58
nosrettap58
nosrettap58's Avatar
Drives: 2023 Camaro 2SS Convertible
performance chips
Sorry if this has been brought up before, but i'm curious if anyone has a plug and go type performance chip. I've had them before with pretty good luck, hp gains, torque, and even higher rpm capabilities. I have a 23 SS, manual, and saw an ad for rocket chip. Pretty cheap @ about $100, so pretty skeptical. Also smart tune @ $150. Don't want to interface and run a program from a computer, just a plug and go. Like i said, i have had these on prior vehicles with success, and if anyone has one on their Camaro, what do you have and how is it working. Any recommendations appreciated.
nosrettap58 is offline   Reply With Quote
Old 02-14-2024, 11:05 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
nope they dont do anything just get a real tune after you add some bolt ons
Old 02-15-2024, 10:28 AM   #3
ctrlz
Originally Posted by nosrettap58 View Post
so pretty skeptical...
Always be skeptical.
You can get more power by running too lean in the open loop modes, but that is a bad thing.
And before someone corrects me...
The open loop modes like hard accel are typically tuned to run rich, i.e. on the safe side, to prevent going overly lean and causing engine damage. So, a "performance chip" can push it closer to stoich, which results in more power at the expense of added risk.
Old 02-15-2024, 12:34 PM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
A canned tune performance chip won't do much and is a waste of money. You can find a remote tuner and use a plug in tuner to get generic tunes based on your mods that have helped me in the past. A dyno tune or street tune is at the top of the list.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 02-15-2024, 12:49 PM   #5
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
+1 to get a real tuner, plenty of guys here on the forums with real world experience that can point you in a safer direction.
Search is your friend.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
