03-21-2016, 06:30 PM | #29 |
Drives: 2016 1SS Yellow Join Date: Aug 2015
What could be the reason for going with the taller gear ratios (less aggressive) as opposed to the shorter ones? The taller gear ratios are generally associated with better fuel economy.. but the SS manual just gets 1 better than last gen? So then was it used with the intention of reducing the weight of the transmission?
1SS,Yellow,Gray Wheels,Black bow ties,NPP.
03-21-2016, 08:44 PM | #30 |
Acceleration is greatest in first gear and drops off each gear. So extending the highest rate of acceleration to 54mph helps 0-60 times. If you shift earlier to second then that point until 54mph you are accelerating slower. It may be a disadvantage to have the extra shift at the track but this close ratio is better on the road course.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
03-21-2016, 08:53 PM | #31 | |
Drives: SS 6 speed of course Join Date: Jan 2016
http://www.richmondgear.com/pdf/Rich...n1.pdf#page=25
03-21-2016, 08:58 PM | #32 | |
a torsen looks good, no clutch to wear:
http://www.justdifferentials.com/TOR...m8.6irs-32.htm Auburn pro http://www.justdifferentials.com/AG5.../ag5420138.htm an Eaton based torsen http://www.justdifferentials.com/TT9.../tt912a686.htm Assuming if the center section takes the same gear it will take the same diff...
