Old 12-19-2023, 04:29 PM   #1
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Brake pedal travel after brake pad change
I just changed the front pads in my 2SS (4 piston Brembos) to Power Stop ceramic pads. I did the pad break in, but now the brake pedal travels a lot further toward the floor before activating the brakes. I did not bleed the brake lines yet, is that what I need to do? Or is there something else?
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint
RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit
My Camaro Journal
Old 12-19-2023, 04:58 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Technically you shouldn’t need to bleed the brakes if you carefully retracted your pistons, not sure why your travel would change as opposed to braking performance as that will decrease with said new brand of brake pads. I run the same brand and to me it is worth the dust to performance trade off, but I also don’t track my car
Old 12-20-2023, 08:52 AM   #3
cdb95z28
cdb95z28's Avatar
A different pad may have different pedal feel. Ceramic is not the most performance/feel oriented pad material.
While bed in can induce pad fade, which is a decrease in friction with a firm pedal, if you got your brakes extremely hot you may have boiled your fluid. Especially if it is very old or original. You said it now has a long pedal. Would you say the pedal is also softer? And the long pedal is still there after a cool down to ambient temps?
Pedal feel after pad fade typically will allow the friction to return once cooled down. As I mentioned fade usually is still a firm pedal.
Then there is hot compressability which is the pedal (fluid) softening when the fluid gets hot, but once cooled to ambient, the pedal returns to the original feel. The fluid doesn't get hot enough to boil.
And finally if the fluid got hot enough to boil, boiled fluid will stay soft, even after the brakes have cooled to ambient.
Old 12-20-2023, 11:32 AM   #4
DamonZ28
DamonZ28's Avatar
I'm the 2nd owner, but car has 36,000 miles so I'm guessing it's the original fluid. The pedal might be a little softer, but I notice it's mostly just longer. I did 4-5 40-10 stops and 4-5 35-5 stops per the directions on the pads. Not sure if that would be enough to boil the fluid? Anyway, I've driven the car to work (about 30 miles round trip) a couple of times, and the pedal hasn't changed. I think I'll definitely do a fluid bleed/change very soon & see if that helps.
Would it have anything to do with the metal "clip" that goes over the pads? The clip that Powerstop sent doesn't even resemble the clip that was originally on the pads, and it bows out quite a bit. I can get a pic shortly during lunch break. I kept the original clips & pads since there's still about half of the life left on the pads (in case I need pads in a pinch).
My Camaro Journal
Old 12-20-2023, 02:21 PM   #5
DamonZ28
DamonZ28's Avatar
Here are the pics of the clips sticking out.
My Camaro Journal
Old 12-20-2023, 02:47 PM   #6
DamonZ28
DamonZ28's Avatar
I also checked my brake fluid. It's maybe 1/4 inch low, and very dark brown, almost black. Definitely time to change it out.
My Camaro Journal
Old 12-30-2023, 06:47 PM   #7
DamonZ28
DamonZ28's Avatar
I bled/replaced the brake fluid today. I had also messaged Power Stop. They said I had installed the brake springs backwards, so I also turned them around. Now the brakes are better than they were before. Very pleased with how it turned out. This is how they're supposed to look, along with a pic of the bleeding process.
My Camaro Journal
Old 12-30-2023, 07:05 PM   #8
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Those springs are installed backwards, you need to turn them around...
EDIT: Just saw you found that out from PowerStop...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 12-30-2023, 07:08 PM   #9
DamonZ28
DamonZ28's Avatar
You must have missed my last post just 20 minutes before - I did turn them around today.
My Camaro Journal
Old 12-30-2023, 07:10 PM   #10
2SS Capt
2SS Capt's Avatar
Yeah, as soon as I saw the picture of them backwards I just hit reply to that post, glad you got it squared away...
How easy was the bleeding/replacing the brake fluid? I think I may do mine with some high temp stuff...
Old 12-30-2023, 07:28 PM   #11
DamonZ28
DamonZ28's Avatar
It was very easy. I used the Allstar Performance Bleeder Bottle (see pic above, Amazon link http://a.co/d/9LfS4fi) and just pumped the brakes to bleed the fluid. Took about 15-20 pumps for the rear brakes on the first bleeder screw (less pumps on the 2nd bleeder screw), but only about 10-15 pumps for the fronts.
Here are the steps I did, just in case you don't know (or others reading the post):
1. Crack open the brake fluid reservoir & make sure it's full. I used a fluid transfer pump & sucked the old fluid out of the reservoir, and replaced it with new fluid to cut down on the bleeding time a little.
2. Start with the brakes furthest from the fluid reservoir & move closer. Passenger rear, driver rear, passenger front, driver front.
3. 4 piston Brembos have 2 bleeder screws, make sure to bleed both on each caliper.
4. Make sure to keep the brake fluid topped off after bleeding each bleeder screw.
You could also use the Mityvac hand pump system, but I think that would make my hand sore, lol.
My Camaro Journal
Old 12-30-2023, 07:42 PM   #12
2SS Capt
2SS Capt's Avatar
Awesome, thanks!
I've changed the fluid on a couple of my other cars just never this one, which fluid did you go with? And how much fluid does the entire system take (how much do I need to buy?)
Old 12-30-2023, 08:16 PM   #13
DamonZ28
DamonZ28's Avatar
Awesome, thanks!
I just went with Prestone DOT 4 synthetic. I used almost 2 quarts. You might get away with using a little over a quart, but I had some gunk in the fluid reservoir so I sucked the fluid out about 4 times, in addition to the bleeding. Not sure where the gunk came from.
I've seen Motul RBF 600 Dot-4 Synthetic Racing Brake Fluid recommended here. $61 for 2 liters, vs. $25 for 2 quarts.
My Camaro Journal
Old 01-01-2024, 11:11 PM   #14
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Alot of information on this topic from one of the threads you can find in the DIY forum- https://www.camaro6.com/forums/showthread.php?t=545244
Ventmaster is offline   Reply With Quote
