12-28-2016, 07:41 PM | #1 |
Drives: 2010 2SS/RS W/ Kenne Bell 2.8LC SC Join Date: Aug 2009
Need Help Alpine W910, Imprint H100, Fark Harness.
Hey all, I need some help. Been working on this thing all day.
I've wired up a new radio setup that I purchased via this forum I have a W910 Head Unit and an Imprint H100 Audio Processor Everything seems to be wired up correctly. I have the H100 going to the HU via the provided cable and the sub/front/rear cables going back to the FARK harness into the rear amp via RCA as well as a separate sub amp. If I unplug the FARK harness from the rear amp and power on the Headunit fully, and then plug in the Fark harness back in the system works great with no issues. Sounds great. However, If I power off the car, and try to power back on the car the system will not turn on. There is a "pop" noise in the speakers as if the Head unit is trying to power on and then power back off. I've been working on this for most of the day, and unplugging the Fark harness for the Head unit power up is the closest I've come to getting this thing to work. Any ideas would be greatly appreciated. I Have an earlier version of the FARK Harness since I got it back in 2010. I've seen some threads about a resistor or grounding something, but cannot find these install instructions. Please Help!
Loving every minute!
2SS/RS L99 - Delivered 8/8/09 1/4: 13.330 @ 105.52 MPH - bone stock |
12-29-2016, 01:12 AM | #2 |
In case anyone was curious.
Apparently the Imprint H100 was sending a feedback loop during start up via the Fark harness back the the head unit and shutting it down. I cut all the wires in the Fark harness that were leading to the RCA outs (leaving the orange and white connected) and voila. Full function and the system sounds amazing. This has been a full day of frustration so hopefully this helps out someone else with the same problem.
12-29-2016, 01:16 AM | #3 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
I had this exact set up 3 years ago, I had zero issues, I installed it myself. Take a picture of your splices, also what did you ground your amps to?
12-29-2016, 01:19 AM | #4 | |
12-31-2016, 01:46 PM | #5 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
A FARK harness by itself is only needed when you have a Boston Acoustic factory system and you want to :
1. Add a subwoofer to your factory BA head unit and keep the factory amplifier or 2. Remove the factory BA amp and replace it with an aftermarket amp. The full FARK kit comes with the RCA interface as well as factory speaker wiring interface. Since you ran RCA cables from the Imprint unit to your amps, there was no need to use the RCA interface part of the FARK kit. |
