Roto-Fab
Old 01-11-2016, 07:27 PM   #1
BlackIce1066
Black Ice
BlackIce1066's Avatar
Drives: 2SS/RS Black w/ silver ice stripes
Key Fob
Well it happened. One of my key FOB's gave out . The unlock button caved in so I had to go to my other one. Bought the car June of 2010 brand new and have signed off on the recall. I want to order an other one but do not want to get it without the key on it.
Does anyone know if I can just get the pad portion of the FOB?
BlackIce1066 is offline   Reply With Quote
Old 01-11-2016, 09:25 PM   #2
BurnedRubber
Ben Rakers
BurnedRubber's Avatar
Drives: 2011 Camaro 2SS/RS
just buy an uncut fob and transfer the key, there are a few tutorials on how to do that and then sync the fab to your car. i believe its just the generic chevy fob.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g
BurnedRubber is offline   Reply With Quote
Old 01-11-2016, 10:13 PM   #3
Houseofhotrods
Houseofhotrods's Avatar
Drives: 2015 GAZ 1LE/2SS/RS/NPP
GM Part # 20979469, along with key code, ordered from a GM parts department will get you the key, cut, attached to the transmitter. Easy to learn to the vehicle and should be about 50-60 bucks. There's other ways to go, but 'turn-key' is pretty cool. This is for a manual trans (no remote start) so if you have an auto will be a diff #.
Keep calm, Grab Gears and Carry On
Houseofhotrods is offline   Reply With Quote
Old 01-12-2016, 05:25 AM   #4
BlackIce1066
Black Ice
Cool. Thanks. I do have a standard trans so I'll check into it.
Old 01-12-2016, 06:29 AM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
When the new fob gets there, why not push the pin out of your current fob, take "the blade" out and reinstall in the new fob? The car may still need the learning process for the new fob, but at least you'll know that the key will work.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-12-2016, 07:28 AM   #6
USMC SGT
Drives: 2021 1SS 1LE
I just bought a key from the dealer a few weeks ago. It came cut and in the fob, they didn't remove it. It only take a few seconds for the car to learn the new key and its easy to do yourself.
USMC SGT is offline   Reply With Quote
Old 01-12-2016, 10:00 AM   #7
hazy
Drives: 2011 2SS/RS
Amazon has the cases for cheap. Basically you'd just need to transfer the guts of the key (circuit board and actual key). I'll be doing this shortly, as my trunk button did the exact same thing about 2 weeks ago, and now I have a hole in one of my fobs
hazy is offline   Reply With Quote
Old 01-12-2016, 12:37 PM   #8
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
This sounds like the simplest solution. I did this for my Grand AM remote when the casing cracked off too much.
GrandAmGT is offline   Reply With Quote
Old 01-13-2016, 09:58 AM   #9
hazy
Drives: 2011 2SS/RS
Just a bump - found these guys on amazon - I'm putting my order in today...figure all I'll need to do is swap the actual key part, reprogram, and life is good.
http://www.amazon.com/gp/product/B00...A392A0WD8JJN37
