07-03-2013, 12:08 PM | #1 |
Drives: 2012 Chevy Camaro convertible Join Date: Jun 2013
Squeal / Whistle in front end, louder when engine revved
Hello, I currently own a 2012 SS covertible camaro. The last few times I have driven it, I notice a squeal/whistle in the front end. Sounds like a belt? and it gets louder if I rev it up! Any idea's of what it could be. Less than 5,000 miles on the camaro. Also, I removed factory airbox and put in a different one do I have to put the factory one back in if I take it in for service...will it void the warranty by not have factory airbox? thanks!
07-03-2013, 12:44 PM | #2 |
Drives: 2012 Camaro LS Join Date: Sep 2012
Intake won't void your warranty.
Is everything with your intake secured properly (mainly the pipes), that could be part of it. |
07-03-2013, 01:33 PM | #3 |
hi. thanks for the reply. Yep, it is secured. I installed a K & N typoon according to the directions.
07-03-2013, 03:13 PM | #4 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Is it a squeal, or is it a whistle? Different sounds.
When I see "whistle" I read "vacuum leak"
07-04-2013, 08:03 AM | #5 |
It is a squeel. Seemds like it is by the a.c. but real difficult yo tell for sure....it sometimes goes away after engine is warmed....
07-04-2013, 08:49 AM | #6 |
Drives: 2011 camaro 2ss/rs rally yellow L99 Join Date: Nov 2011
Pop the hood get a buddy to rev it and have a look yourself. Just a thought if you haven't tried that yet, you might see something.
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap |
07-04-2013, 09:22 AM | #7 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Some have had issues with the AC belt partially walking off of the pullies.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
07-04-2013, 03:21 PM | #8 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
Up...belt/compressor went 416mi on my car.
-John S.
07-17-2013, 10:36 PM | #9 |
Thanks everyone I found that the ac belt was actually split in two...took it to the dealer for replacement.all seems good so far! They measured clearances, and all seems to be in order....we shall see!
07-17-2013, 10:42 PM | #10 |
Drives: 2011 Camaro 2SS/RS CGM/BLI A6 Join Date: Jul 2011
The harmonic balancer had to be replaced on my car after it ate two AC compressor belts.
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back. FUTURE: long tube headers, front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings. WISH LIST: Edelbrock E-Force SC, LS3 conversion |
07-17-2013, 11:25 PM | #11 |
Drives: 2019 2SS Riverside Blue Join Date: Aug 2011
I get a little noise when the AC is on, its similar to a steering pump but barely audible and I only hear it when the rpms are high just before a gear change in 1st and 2nd.
07-18-2013, 09:45 AM | #12 |
Glad you found it!
07-18-2013, 09:47 AM | #13 |
OFF THE CHAIN
A/C Belt is the most common whistle under the hood, do like others suggested and open the hood while someone punches the gas and look for the culprit
07-18-2013, 11:57 AM | #14 |
I heard a whistling and I checked it out. It was my A/C belt coming off the pulley. After taking it to chevy several times, they replaced the pulley. Everything was done under warranty and I have an intake. I'm also tuned, but I changed back to stock when I took it in.
