06-14-2017, 04:14 PM | #1 |
Drives: 2016 Camaro SS in Red Hot Join Date: Apr 2016
Water Spots
Went out to lunch and found that a rogue sprinkler from the park next door to my office had sprayed my car, and the 102-degree heat had baked the spots to my paint. Gonna have to wait a couple hours before I can go home and deal with this. Once before I tried a 50-50 mixture of water and vinegar and it worked, so I think I'll do the same again. My fear is that our scorching sun and hard water could've left mineral deposits that--if left too long--will etch the paint.
06-14-2017, 04:20 PM | #2 |
Retired from Car mfrs....
The vinegar will do it. Also if you're worried about minerals, put a little bit of CLR on a rag and see if that gets it.
06-14-2017, 04:28 PM | #3 |
06-14-2017, 08:16 PM | #4 | |
Drippin' Wet Auto Detail
If those 2 options do not work, ive always had good success with CarPro Spotless.
Made a video about it below also if you are interested https://www.amazon.com/gp/product/B0...2ef1107e01fc7c |
06-15-2017, 10:21 AM | #5 |
Went home yesterday, parked the car in the shade and sprayed it down with a vinegar/water mixture. Rinsed it off, then washed it with my regular car shampoo. While it was still wet, I sprayed it down with the vinegar solution again, then rinsed and dried. Spots were still visible. Used my Porter-Cable buffer with a medium-density pad and some scratch/swirl remover and did the whole car. It's shiny as all get-out, but I can still see "ghost spots"--nothing in the middle, but a faint rim outlining the water droplet. Since you have to look really carefully to see these spots, I'm calling it quits for now. Hoping that future washings and waxings will gradually wear these things off.
06-15-2017, 10:23 AM | #6 | |
If you are in an area where this may happen again, an sio2 coating is your best defense, or a cover. |
06-15-2017, 10:27 AM | #7 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Options are: More passes with same pad/polish More aggressive polish More aggressive pad More aggressive machine.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
06-15-2017, 10:53 AM | #8 | |
06-15-2017, 10:58 AM | #9 |
Good, I just reread this and saw you used scratch/swirl remover, that's fairly light stuff, I'm sure meguire's ultimate compound from the auto parts store will get it, its great all purpose stuff.
06-15-2017, 11:11 AM | #10 |
LOVE Meguiar's Ultimate Compound! Always have some on hand. But I'm like you--didn't use the "nuclear option" because I like to err on the side of being as unaggressive as possible.
06-15-2017, 11:13 AM | #11 |
Also, turn up your speed a bit for correcting....like 75% of the speed range.
06-15-2017, 11:28 AM | #12 | |
Check out Autopia's Polish Comparison Chart Updated 02/2017 to see the cut level of all the major polishes.
06-15-2017, 11:31 AM | #13 | |
http://www.autogeek.net/meguiars-ultimate-compound.html |
06-15-2017, 11:53 AM | #14 |
Did precisely that when I detailed my son's 2011 Volkswagen GTI last weekend. He'd been away for his freshman year in college and came back with the car all spotted and scratched. Went over the whole thing with Ultimate Compound, with the buffer turned up a notch. Turned out really nice. Got rid of most of the defects.
