TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 05-15-2017, 06:06 PM   #1
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
4.10 Gears?
Hey guys. So I just had a cam installed and it likes to buck like a bronco under 1500rpm's. I've read that by upping your gear ratio it will help offset that by getting you through the RPM's quicker. I have a 2010 SS LS3. I've done some research and cant really find a definitive answer on what brand I should go with. Obviously for 3.91's you should go with GM. But there doesn't seem to be a quite so obvious choice for the 4.10's.
Also, I see where you can buy just the 4.10 gears or the installation package that adds another $250 to the price. Do you need to buy the installation package if you are taking it to a shop or is that for people who are trying a DIY?
Thanks in advance for all the help!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 05-15-2017, 06:13 PM   #2
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
I run Motive. Some whine at 45-55 but nothing that big deal to me. They arent set up perfect either so they could be a touch quieter.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 05-15-2017, 06:21 PM   #3
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Richmond sells a 4.11.
https://www.richmondgear.com/auto-pa...size%3A6.2%2Bl
Ask your installer about the install kit. Some want it, some have their own parts.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 05-15-2017, 06:42 PM   #4
Bo White
Bo White's Avatar
I like 4.10s over 4.11s
Totalled:
Old 05-15-2017, 08:47 PM   #5
Gunmetal Speedster
I have read this preference.
Bo, are these the gears you have? Motive 4.10's
Old 05-15-2017, 10:44 PM   #6
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Why would you want 4.10's when the GM 3.91's are so readily available and inexpensive?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 05-16-2017, 12:52 AM   #7
Gunmetal Speedster
I figure in my case it will help a little extra, the bucking is quite annoying. The sooner and easier I get passed that rpm range the better. 4.10's will do it quicker. Not to mention, my cam lost a noticeable amount on low end torque, I would assume the 4.10's would also give me some of that butt dyno feeling back of a strong low end pull haha.
Old 05-16-2017, 02:38 AM   #8
Bo White
Bo White's Avatar
3.91 is what the SS should have came with. My G8 GXP came 3.70 with a shorter tire than the SS and it was near perfect fo the stock LS3. Cam the LS3 and it would benefit from a steeper gear.
BFASTNOTLAST is looking to go from 4.10 to 4.33 even.
I love my Motive 4.10s, goes great with my daily driver th400 swapped ride.
Totalled:
Old 05-16-2017, 06:43 AM   #9
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
You want all the gear you can get in a M6 5th gen. Motive gears tend to be more quiet and you might consider getting them rem polished, as Bo said the 4.10 is the stronger pattern. If I could get 4.56 for my 1LE they would already be in it. Install kit is needed but some shops have shims left over and you can get by with a half kit.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 05-16-2017, 08:44 AM   #10
Swacer
Drives: 2018 GT350
I went with 3.91 in my swap. It bucks a little from 1500-2000k, but its workable without issue. I debated on 4.10 gears, but ultimately got away from them due to the potential of whine and with 4.10 those teeth are so small.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 05-16-2017, 08:54 AM   #11
Avenging Orange
I never had 'bucking' issues with my cammed cars. You eventually figure out how to drive them (which is the goal). I know there was a lot of discussion about irrelevance when folks were wanting to swap the 3.45's for 3.73 or 3.70.
Just curious why the same doesnt apply for 3.91 to 4.10?
I'm no math wiz....but I would see it as not worth the extra money for a few more teeth.
Old 05-16-2017, 10:27 AM   #12
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Alas you have discovered the "dirty" little secret 'bout bigger cams...for motor heads it's a "who gives a rats patooty" however for the DD'rs ...hmmmm..not so much...
I freakin luv the fact I can practically drive over the mountain in my backyard in 4th! All the way...and no luggin....now when I DO put in some steeper gears I will be hard pressed between the 3.91 and 4.10's...and when I do it since my mileage is so high I will use a full install kit for the new bearings...AND a LPW cover!
Now the steeper gears as said above won't fix the below 1500k...just covers it up nice since you HAVE to leave from a stop with higher rpm's....you have all summer to get used to it! peace out!....
BTW - side benefit is since you will be shiftin gears more your gear bangin skillz "should"improve too!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-16-2017, 11:12 AM   #13
Swacer
Drives: 2018 GT350
Agree with this. The car isn't my DD, so the occasional bucking doesn't really concern me. My builder said the BTR S4 is going to cause that, and the ported heads were going to exaggerate that a little further. Just the nature of the beast, I gotta just adapt my driving.
I got the LPW rear cover when I had the gears swapped.
Old 05-16-2017, 01:42 PM   #14
Bo White
Bo White's Avatar
Its not that you leave at a higher rpm its more so your not in the lower rpm as long. Also less load against the engine helps with it too.
Totalled:
